iPhone 17 Pro Rear Camera Assembly Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 17 Pro Rear Camera Assembly Removal, Remove the rear camera connector cover: step 1, image 1 of 2 iPhone 17 Pro Rear Camera Assembly Removal, Remove the rear camera connector cover: step 1, image 2 of 2
      • Use a tri-point Y000 screwdriver to remove the 1.0 mm‑long screw securing the rear camera connector cover.
      Ask FixBot
    2. iPhone 17 Pro Rear Camera Assembly Removal: step 2, image 1 of 3 iPhone 17 Pro Rear Camera Assembly Removal: step 2, image 2 of 3 iPhone 17 Pro Rear Camera Assembly Removal: step 2, image 3 of 3
      • Use tweezers to unlatch the rear camera connector cover from the logic board and remove it.
      Ask FixBot
    3. iPhone 17 Pro Rear Camera Assembly Removal, Disconnect the rear camera assembly: step 3, image 1 of 3 iPhone 17 Pro Rear Camera Assembly Removal, Disconnect the rear camera assembly: step 3, image 2 of 3 iPhone 17 Pro Rear Camera Assembly Removal, Disconnect the rear camera assembly: step 3, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the three rear camera press connectors.
      • One of the connectors is under the other.
      Ask FixBot
    4. iPhone 17 Pro Rear Camera Assembly Removal, Remove the rear camera assembly: step 4, image 1 of 1
      • Use a Torx Plus 4IP screwdriver to remove the three screws securing the rear camera assembly:
      • Two 4.0 mm‑long screws
      • One 4.4 mm‑long screw
      Ask FixBot
    5. iPhone 17 Pro Rear Camera Assembly Removal: step 5, image 1 of 3 iPhone 17 Pro Rear Camera Assembly Removal: step 5, image 2 of 3 iPhone 17 Pro Rear Camera Assembly Removal: step 5, image 3 of 3
      • Use the point of a spudger to pry up the top edge of the rear camera assembly.
      • Grab the assembly with your fingers and remove it.
      Ask FixBot
Arthur Shi
350,827 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 98
