iPhone 17 Pro Max Rear Camera Assembly Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 17 Pro Max Rear Camera Assembly Installation, Install the rear camera assembly: step 1, image 1 of 2 iPhone 17 Pro Max Rear Camera Assembly Installation, Install the rear camera assembly: step 1, image 2 of 2
      • Lay the rear camera assembly in its recess.
      Ask FixBot
    2. iPhone 17 Pro Max Rear Camera Assembly Installation: step 2, image 1 of 3 iPhone 17 Pro Max Rear Camera Assembly Installation: step 2, image 2 of 3 iPhone 17 Pro Max Rear Camera Assembly Installation: step 2, image 3 of 3
      • Use your finger to press and connect the three camera press connectors onto the logic board.
      Ask FixBot
    3. iPhone 17 Pro Max Rear Camera Assembly Installation: step 3, image 1 of 2 iPhone 17 Pro Max Rear Camera Assembly Installation: step 3, image 2 of 2
      • Use a Torx Plus 4IP screwdriver to install the three rear camera assembly screws:
      • Two 4.0 mm‑long screws
      • One 4.4 mm‑long screw
      • Make sure to install this in the proper screw hole.
      Ask FixBot
    4. iPhone 17 Pro Max Rear Camera Assembly Installation, Install the rear camera connector cover: step 4, image 1 of 3 iPhone 17 Pro Max Rear Camera Assembly Installation, Install the rear camera connector cover: step 4, image 2 of 3 iPhone 17 Pro Max Rear Camera Assembly Installation, Install the rear camera connector cover: step 4, image 3 of 3
      • Use tweezers to latch the rear camera connector cover onto the logic board and lay it in place.
      Ask FixBot
    5. iPhone 17 Pro Max Rear Camera Assembly Installation: step 5, image 1 of 1
      • Use a tri-point Y000 screwdriver to install the 1.0 mm‑long camera connector screw.
      Ask FixBot
Arthur Shi
350,804 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 95
