iPhone 17 Pro Max Lower Microphone Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 17 Pro Max Lower Microphone Installation, Remove the microphone adhesive gasket: step 1, image 1 of 1
      • If the adhesive gasket isn't deformed and your lower microphone didn't come with a replacement gasket, you can keep and reuse the gasket. Be aware that you'll lose water and dust resistance.
      • Use tweezers to remove the microphone adhesive gasket from the frame.
      Ask FixBot
    2. iPhone 17 Pro Max Lower Microphone Installation, Install the lower microphone: step 2, image 1 of 3 iPhone 17 Pro Max Lower Microphone Installation, Install the lower microphone: step 2, image 2 of 3 iPhone 17 Pro Max Lower Microphone Installation, Install the lower microphone: step 2, image 3 of 3
      • If your replacement lower microphone comes with an adhesive gasket pre-installed, make sure to remove any liners to expose the adhesive.
      • Use tweezers to align the microphone with the frame.
      • Slide the microphone into its recess and press it in place. There should be almost no gap between the microphone and the frame.
      Ask FixBot
    3. iPhone 17 Pro Max Lower Microphone Installation: step 3, image 1 of 1
      • Use a hair dryer or an iOpener to heat the lower microphone until it's warm to the touch. This helps strengthen the adhesive bond.
      Ask FixBot
    4. iPhone 17 Pro Max Lower Microphone Installation: step 4, image 1 of 2 iPhone 17 Pro Max Lower Microphone Installation: step 4, image 2 of 2
      • Install the two lower microphone screws:
      • One 3.2 mm-long standoff screw
      • One 3.1 mm-long JIS 00 screw attached to the bottom edge of the iPhone frame
      Ask FixBot
    5. iPhone 17 Pro Max Lower Microphone Installation: step 5, image 1 of 1
      • Use your finger to press and connect the lower microphone press connector.
      Ask FixBot
Arthur Shi
350,781 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 91
