Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Spudger4.9
Tool used on this step:Tweezers$4.99
Use blunt-nose tweezers or your fingers to remove large pieces of adhesive from the frame.
Use a spudger to scrape the adhesive residue off the frame.
Without peeling any liners, lay the adhesive sheet over the frame to determine its proper orientation.
Grab the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
Position the back glass so you can comfortably reconnect it.
Use your finger or a spudger to press and connect the back glass press connector onto the logic board.
