iPhone 17 Pro Loudspeaker Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 17 Pro Loudspeaker Installation, Install the loudspeaker: step 1, image 1 of 3 iPhone 17 Pro Loudspeaker Installation, Install the loudspeaker: step 1, image 2 of 3 iPhone 17 Pro Loudspeaker Installation, Install the loudspeaker: step 1, image 3 of 3
      • Align the bottom edge of the loudspeaker with the frame and lay it in its recess.
      • Make sure the bottom-right screw tab seats properly against the frame. Gently bend it if it's out of place.
      • Use your finger to press down on the loudspeaker until it clicks in place.
      Ask FixBot
    2. iPhone 17 Pro Loudspeaker Installation: step 2, image 1 of 2 iPhone 17 Pro Loudspeaker Installation: step 2, image 2 of 2
      • Use a JIS 00 screwdriver to install the six loudspeaker screws:
      • Two 2.7 mm‑long screws
      • Two 2.0 mm‑long screws
      • One 1.5 mm‑long screw
      • One 1.5 mm‑long screw attached to the bottom edge of the iPhone frame
      Ask FixBot
    3. iPhone 17 Pro Loudspeaker Installation, Install the buffer strip: step 3, image 1 of 3 iPhone 17 Pro Loudspeaker Installation, Install the buffer strip: step 3, image 2 of 3 iPhone 17 Pro Loudspeaker Installation, Install the buffer strip: step 3, image 3 of 3
      • Use your fingers or a spudger to press the buffer strip back onto the top edge of the Taptic Engine.
      Ask FixBot
Arthur Shi
350,824 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 16
All Time: 77
