iPhone 17 Pro Logic Board Intermediate Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 17 Pro Logic Board Intermediate Installation, Install the logic board: step 1, image 1 of 3 iPhone 17 Pro Logic Board Intermediate Installation, Install the logic board: step 1, image 2 of 3 iPhone 17 Pro Logic Board Intermediate Installation, Install the logic board: step 1, image 3 of 3
      • Use an opening pick to hold the flex cables along the left edge of the iPhone to prevent them from being trapped underneath the logic board.
      • Swing the logic board down in place, making sure no flex cables are trapped along the left and bottom edges.
      Ask FixBot
    2. iPhone 17 Pro Logic Board Intermediate Installation: step 2, image 1 of 1
      • Check the right edge of the logic board to make sure the power button connector wasn't trapped underneath the logic board.
      Ask FixBot
    3. iPhone 17 Pro Logic Board Intermediate Installation: step 3, image 1 of 1
      • Use your finger to press and connect the small button connector on the left side of the logic board.
      • Stop if the connector feels like it won't reach. The button cable has a bend that often catches underneath the logic board. Lift the logic board, free the cable bend, and try again.
      Ask FixBot
    4. iPhone 17 Pro Logic Board Intermediate Installation: step 4, image 1 of 1
      • Use your finger to press and attach the six press connectors:
      • Two connectors along the top edge of the logic board
      • One remaining button board connector
      • Two USB-C port assembly connectors (one on top of the other)
      • One power button connector
      Ask FixBot
    5. iPhone 17 Pro Logic Board Intermediate Installation, Install the button connector cover: step 5, image 1 of 3 iPhone 17 Pro Logic Board Intermediate Installation, Install the button connector cover: step 5, image 2 of 3 iPhone 17 Pro Logic Board Intermediate Installation, Install the button connector cover: step 5, image 3 of 3
      • Latch the end of the button connector cover onto the logic board.
      Ask FixBot
    6. iPhone 17 Pro Logic Board Intermediate Installation: step 6, image 1 of 1
      • Use a tri-point Y000 screwdriver to install the 1.0 mm‑long button connector screw.
      Ask FixBot
    7. iPhone 17 Pro Logic Board Intermediate Installation, Install the top speaker: step 7, image 1 of 2 iPhone 17 Pro Logic Board Intermediate Installation, Install the top speaker: step 7, image 2 of 2
      • Align the top edge of the top speaker with the iPhone.
      • Lay the speaker in its recess.
      Ask FixBot
    8. iPhone 17 Pro Logic Board Intermediate Installation: step 8, image 1 of 1
      • Use a JIS 00 screwdriver to install the three 2.2 mm‑long top speaker screws.
      Ask FixBot
    9. iPhone 17 Pro Logic Board Intermediate Installation, Install the front camera assembly: step 9, image 1 of 1
      • Lay the front camera assembly in its recess.
      Ask FixBot
    10. iPhone 17 Pro Logic Board Intermediate Installation: step 10, image 1 of 3 iPhone 17 Pro Logic Board Intermediate Installation: step 10, image 2 of 3 iPhone 17 Pro Logic Board Intermediate Installation: step 10, image 3 of 3
      • Use your fingers to press and connect the two front camera assembly connectors.
      Ask FixBot
    11. iPhone 17 Pro Logic Board Intermediate Installation, Install the front camera connector cover: step 11, image 1 of 3 iPhone 17 Pro Logic Board Intermediate Installation, Install the front camera connector cover: step 11, image 2 of 3 iPhone 17 Pro Logic Board Intermediate Installation, Install the front camera connector cover: step 11, image 3 of 3
      • Hook the small latch in the corner of the camera connector cover onto the logic board and set it in place.
      Ask FixBot
    12. iPhone 17 Pro Logic Board Intermediate Installation: step 12, image 1 of 1
      • Use a tri-point Y000 screwdriver to install the 1.0 mm‑long front camera connector screw.
      Ask FixBot
Arthur Shi
350,744 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 71
