Shop the Holiday Gift Guide
iPhone 17 Pro Front Camera Assembly Removal
View statistics:
Past 24 Hours:
Past 7 Days:
3
Past 30 Days:
6
All Time:
86
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. iPhone 17 Pro Front Camera Assembly Removal, Remove the front camera connector cover: step 1, image 1 of 1
      • Use a tri-point Y000 screwdriver to remove the 1.0 mm‑long screw securing the front camera connector cover.
      Ask FixBot
    2. iPhone 17 Pro Front Camera Assembly Removal: step 2, image 1 of 2 iPhone 17 Pro Front Camera Assembly Removal: step 2, image 2 of 2
      • Use tweezers to unhook and remove the front camera connector cover.
      Ask FixBot
    3. iPhone 17 Pro Front Camera Assembly Removal, Remove the front camera assembly: step 3, image 1 of 3 iPhone 17 Pro Front Camera Assembly Removal, Remove the front camera assembly: step 3, image 2 of 3 iPhone 17 Pro Front Camera Assembly Removal, Remove the front camera assembly: step 3, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the two front camera connectors (one's under the other) from the logic board.
      Ask FixBot
    4. iPhone 17 Pro Front Camera Assembly Removal: step 4, image 1 of 3 iPhone 17 Pro Front Camera Assembly Removal: step 4, image 2 of 3 iPhone 17 Pro Front Camera Assembly Removal: step 4, image 3 of 3
      • Use the point of a spudger to pry up the right edge of the front camera assembly.
      • Lift and remove the front camera assembly from its recess.
      Ask FixBot
Arthur Shi
353,987 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 86
