Shop the Holiday Gift Guide
iPhone 16 Pro Max Taptic Engine Installation
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
15
All Time:
224
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Installation steps for the Taptic Engine in the iPhone 16 Pro Max.
Tools
    1. iPhone 16 Pro Max Taptic Engine Installation, Install the Taptic Engine: step 1, image 1 of 1
      • Lay the Taptic Engine in its recess.
      Ask FixBot
    2. iPhone 16 Pro Max Taptic Engine Installation: step 2, image 1 of 1
      • Use your finger to pivot the corner bracket down into place.
      Ask FixBot
    3. iPhone 16 Pro Max Taptic Engine Installation: step 3, image 1 of 1
      • Use a Phillips screwdriver to install the 2.1 mm‑long screw securing the Taptic Engine.
      Ask FixBot
    4. iPhone 16 Pro Max Taptic Engine Installation: step 4, image 1 of 1
      • Use your finger to gently press the lower assembly cable onto the top of the Taptic Engine.
      Ask FixBot
    5. iPhone 16 Pro Max Taptic Engine Installation: step 5, image 1 of 2 iPhone 16 Pro Max Taptic Engine Installation: step 5, image 2 of 2
      • Install the two screws securing the lower assembly cable:
      • One 1.0 mm‑long tri-point Y000 screw
      • One 1.3 mm‑long Phillips screw
      Ask FixBot
    6. iPhone 16 Pro Max Taptic Engine Installation: step 6, image 1 of 2 iPhone 16 Pro Max Taptic Engine Installation: step 6, image 2 of 2
      • Use your finger or a spudger to press and connect the two lower assembly cable connectors.
      Ask FixBot
    7. iPhone 16 Pro Max Taptic Engine Installation: step 7, image 1 of 2 iPhone 16 Pro Max Taptic Engine Installation: step 7, image 2 of 2
      • Lay the Taptic Engine cover in place and align it by its screw holes.
      • Make sure the bottom edge of the cover latches properly to the frame.
      Ask FixBot
    8. iPhone 16 Pro Max Taptic Engine Installation: step 8, image 1 of 2 iPhone 16 Pro Max Taptic Engine Installation: step 8, image 2 of 2
      • Use a Phillips screwdriver to install the three screws securing the Taptic Engine cover:
      • One 2.9 mm‑long screw
      • One 1.3 mm‑long screw
      • One 2.4 mm‑long screw
      Ask FixBot
    9. iPhone 16 Pro Max Taptic Engine Installation: step 9, image 1 of 1
      • Use your finger or a spudger to press the assembly cable connector onto the logic board.
      Ask FixBot
Finish Line
Author
with
Arthur Shi
353,975 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 224
