iPhone 16 Pro Max Rear Camera Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 16 Pro Max Rear Camera Installation, Install the rear camera assembly: step 1, image 1 of 1
      • Lay the rear camera assembly in its recess.
      Ask FixBot
    2. iPhone 16 Pro Max Rear Camera Installation: step 2, image 1 of 1
      • Use a Phillips screwdriver to install the two 2.9 mm‑long screws securing the rear camera assembly.
      Ask FixBot
    3. iPhone 16 Pro Max Rear Camera Installation: step 3, image 1 of 2 iPhone 16 Pro Max Rear Camera Installation: step 3, image 2 of 2
      • Use your finger or a spudger to press and connect the two camera connectors onto the logic board.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
Finish Line
Arthur Shi
350,880 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 17
All Time: 211
