iPhone 16 Pro Max LiDAR Sensor Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. iPhone 16 Pro Max LiDAR Sensor Removal, Remove the LiDAR sensor: step 1, image 1 of 2 iPhone 16 Pro Max LiDAR Sensor Removal, Remove the LiDAR sensor: step 1, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the LiDAR sensor connector.
  2. iPhone 16 Pro Max LiDAR Sensor Removal: step 2, image 1 of 2 iPhone 16 Pro Max LiDAR Sensor Removal: step 2, image 2 of 2
    • Use a Phillips screwdriver to remove the two screws securing the LiDAR sensor:
    • One 1.6 mm‑long screw
    • One 2.9 mm‑long screw
  3. iPhone 16 Pro Max LiDAR Sensor Removal: step 3, image 1 of 2 iPhone 16 Pro Max LiDAR Sensor Removal: step 3, image 2 of 2
    • Use your fingers or tweezers to lift and remove the LiDAR sensor.
Finish Line
Arthur Shi
310,295 Reputation
701 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,648 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 252
