iPhone 16 Plus Back Glass Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 16 Plus Back Glass Removal, Prepare your phone for disassembly: step 1, image 1 of 2 iPhone 16 Plus Back Glass Removal, Prepare your phone for disassembly: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      Ask FixBot
    2. iPhone 16 Plus Back Glass Removal, Tape over any cracks: step 2, image 1 of 2 iPhone 16 Plus Back Glass Removal, Tape over any cracks: step 2, image 2 of 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Ask FixBot
    3. iPhone 16 Plus Back Glass Removal, Mark your opening picks: step 3, image 1 of 3 iPhone 16 Plus Back Glass Removal, Mark your opening picks: step 3, image 2 of 3 iPhone 16 Plus Back Glass Removal, Mark your opening picks: step 3, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    4. iPhone 16 Plus Back Glass Removal, Remove the pentalobe screws: step 4, image 1 of 2 iPhone 16 Plus Back Glass Removal, Remove the pentalobe screws: step 4, image 2 of 2
      • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the USB-C port.
      Ask FixBot
    1. iPhone 16 Plus Back Glass Removal, Heat the bottom edge: step 5, image 1 of 2 iPhone 16 Plus Back Glass Removal, Heat the bottom edge: step 5, image 2 of 2
      • Apply a heated iOpener to the bottom edge of the back glass for two minutes.
      • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Ask FixBot
    2. iPhone 16 Plus Back Glass Removal, Insert an opening pick: step 6, image 1 of 3 iPhone 16 Plus Back Glass Removal, Insert an opening pick: step 6, image 2 of 3 iPhone 16 Plus Back Glass Removal, Insert an opening pick: step 6, image 3 of 3
      • Apply a suction handle to the bottom edge of the back glass, above the USB-C port.
      • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    3. iPhone 16 Plus Back Glass Removal, Back glass information: step 7, image 1 of 2 iPhone 16 Plus Back Glass Removal, Back glass information: step 7, image 2 of 2
      • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
      • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
      • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
      Ask FixBot
    4. iPhone 16 Plus Back Glass Removal, Separate the bottom edge adhesive: step 8, image 1 of 3 iPhone 16 Plus Back Glass Removal, Separate the bottom edge adhesive: step 8, image 2 of 3 iPhone 16 Plus Back Glass Removal, Separate the bottom edge adhesive: step 8, image 3 of 3
      • Don't insert your pick deeper than 5 mm on the bottom edge to avoid damaging the spring contacts.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    5. iPhone 16 Plus Back Glass Removal, Heat the right edge: step 9, image 1 of 2 iPhone 16 Plus Back Glass Removal, Heat the right edge: step 9, image 2 of 2
      • Apply a heated iOpener to the right edge of the back glass for two minutes.
      • When using a hair dryer or heat gun, heat the back glass until it's hot to the touch.
      Ask FixBot
    6. iPhone 16 Plus Back Glass Removal, Separate the bottom right corner adhesive: step 10, image 1 of 3 iPhone 16 Plus Back Glass Removal, Separate the bottom right corner adhesive: step 10, image 2 of 3 iPhone 16 Plus Back Glass Removal, Separate the bottom right corner adhesive: step 10, image 3 of 3
      • Don't insert your pick deeper than 5 mm along the right edge to avoid damaging the spring contacts and ribbon cable.
      • Slide your pick around the bottom right corner and slide it halfway up the right edge, or until you feel a hard stop at a clip securing the back glass.
      • Don't slice near the volume buttons to avoid damaging the wireless charging/flash cable.
      • Leave this pick inserted to prevent the adhesive from resealing.
      Ask FixBot
    7. iPhone 16 Plus Back Glass Removal, Heat the left edge: step 11, image 1 of 2 iPhone 16 Plus Back Glass Removal, Heat the left edge: step 11, image 2 of 2
      Ask FixBot
    8. iPhone 16 Plus Back Glass Removal, Separate the left edge adhesive: step 12, image 1 of 3 iPhone 16 Plus Back Glass Removal, Separate the left edge adhesive: step 12, image 2 of 3 iPhone 16 Plus Back Glass Removal, Separate the left edge adhesive: step 12, image 3 of 3
      • Don't insert your pick deeper than 5 mm along the left edge to avoid damaging the spring contact.
      • Insert a second opening pick at the bottom edge.
      • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
      • You'll hear and feel the metal clips release as you pass them.
      • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    9. iPhone 16 Plus Back Glass Removal, Heat the top edge: step 13, image 1 of 2 iPhone 16 Plus Back Glass Removal, Heat the top edge: step 13, image 2 of 2
      • Apply a heated iOpener to the top edge of the back glass, angled to include the volume buttons, for two minutes.
      • When using a hair dryer or heat gun, heat until it's hot to the touch.
      Ask FixBot
    10. iPhone 16 Plus Back Glass Removal, Separate the top edge adhesive: step 14, image 1 of 3 iPhone 16 Plus Back Glass Removal, Separate the top edge adhesive: step 14, image 2 of 3 iPhone 16 Plus Back Glass Removal, Separate the top edge adhesive: step 14, image 3 of 3
      • Don't insert your pick deeper than 3 mm along the top edge to avoid damaging the spring contacts.
      • Slide your opening pick across the top edge and around the top right corner to the volume up button to separate the adhesive.
      • You should hear and feel clicks as the top two clips release.
      Ask FixBot
    11. iPhone 16 Plus Back Glass Removal, Swing open the back glass: step 15, image 1 of 2 iPhone 16 Plus Back Glass Removal, Swing open the back glass: step 15, image 2 of 2
      • Don't try to fully remove the back glass just yet—it's still attached with a delicate ribbon cable. Follow the next few steps to remove it safely.
      • If the back glass doesn't swing open easily, don't force it—go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
      • You may need to lift the back glass up slightly before swinging it open to fully disengage the clips.
      • Gently swing open the back glass towards the volume buttons.
      • Support the back glass with a clean, sturdy object like a small box to avoid straining the cable.
      • Remove the opening picks.
      Ask FixBot
    12. iPhone 16 Plus Back Glass Removal, Unfasten the middle connector cover: step 16, image 1 of 2 iPhone 16 Plus Back Glass Removal, Unfasten the middle connector cover: step 16, image 2 of 2
      • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the middle connector cover.
      Ask FixBot
    13. iPhone 16 Plus Back Glass Removal, Remove the middle connector cover: step 17, image 1 of 2 iPhone 16 Plus Back Glass Removal, Remove the middle connector cover: step 17, image 2 of 2
      • Be careful not to dent or puncture the battery during this step.
      • Use blunt-nose tweezers or your fingers to slide the cover towards the left edge of the phone and release its hook from its slot on the logic board.
      • Remove the cover.
      Ask FixBot
    14. iPhone 16 Plus Back Glass Removal, Disconnect the battery: step 18, image 1 of 2 iPhone 16 Plus Back Glass Removal, Disconnect the battery: step 18, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    15. iPhone 16 Plus Back Glass Removal, Disconnect the wireless charger: step 19, image 1 of 2 iPhone 16 Plus Back Glass Removal, Disconnect the wireless charger: step 19, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
      Ask FixBot
    16. iPhone 16 Plus Back Glass Removal, Remove the back glass: step 20, image 1 of 2 iPhone 16 Plus Back Glass Removal, Remove the back glass: step 20, image 2 of 2
      • Lift the back glass off the frame and remove it.
      Ask FixBot
Nick Schultz
65,500 Reputation
343 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 16
All Time: 289
