Shop the Holiday Gift Guide
iPhone 15 Pro Screen Installation
View statistics:
Past 24 Hours:
3
Past 7 Days:
6
Past 30 Days:
26
All Time:
170
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite only guide to install the screen on an iPhone 15 Pro.
Parts
Tools
    1. iPhone 15 Pro Screen Installation, Remove the screen adhesive: step 1, image 1 of 3 iPhone 15 Pro Screen Installation, Remove the screen adhesive: step 1, image 2 of 3 iPhone 15 Pro Screen Installation, Remove the screen adhesive: step 1, image 3 of 3
      • The adhesive remaining on the phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
      • Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
      • Use a pair of tweezers, or your fingers, to remove the adhesive around the entire perimeter of the iPhone.
      Ask FixBot
    2. iPhone 15 Pro Screen Installation: step 2, image 1 of 3 iPhone 15 Pro Screen Installation: step 2, image 2 of 3 iPhone 15 Pro Screen Installation: step 2, image 3 of 3
      • Any unevenness will compromise the iPhone's seal. Clean the frame thoroughly.
      • Apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to a cotton swab or lint-free cloth.
      • Wipe along the perimeter of the frame to clean the adhesive residue.
      • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
      Ask FixBot
    3. iPhone 15 Pro Screen Installation, Orient the adhesive: step 3, image 1 of 1
      • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to orient it correctly.
      Ask FixBot
    4. iPhone 15 Pro Screen Installation, Apply the adhesive: step 4, image 1 of 3 iPhone 15 Pro Screen Installation, Apply the adhesive: step 4, image 2 of 3 iPhone 15 Pro Screen Installation, Apply the adhesive: step 4, image 3 of 3
      • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but don't remove it all the way.
      • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
      • When the adhesive is aligned, set it down along the bottom edge.
      Ask FixBot
    5. iPhone 15 Pro Screen Installation: step 5, image 1 of 3 iPhone 15 Pro Screen Installation: step 5, image 2 of 3 iPhone 15 Pro Screen Installation: step 5, image 3 of 3
      • Continue peeling the back liner off of the adhesive while setting the adhesive into place along the edges of the iPhone's frame.
      • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
      • If you don't have another one handy, it's okay to put your iPhone back together without adhesive, but keep in mind that it won't be water resistant until you install new adhesive.
      Ask FixBot
    6. iPhone 15 Pro Screen Installation, Press the adhesive into place: step 6, image 1 of 3 iPhone 15 Pro Screen Installation, Press the adhesive into place: step 6, image 2 of 3 iPhone 15 Pro Screen Installation, Press the adhesive into place: step 6, image 3 of 3
      • Use the flat end of a spudger to press the adhesive into place all around the iPhone.
      • Be careful not to press on the camera, spring contacts, or other internal components.
      Ask FixBot
    7. iPhone 15 Pro Screen Installation, Remove the top liner: step 7, image 1 of 2 iPhone 15 Pro Screen Installation, Remove the top liner: step 7, image 2 of 2
      • Lift the pull tab in the top‑right corner of the frame to peel off the top liner and remove it.
      • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners along the edges.
      Ask FixBot
    8. iPhone 15 Pro Screen Installation, Adhesive information: step 8, image 1 of 1
      • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
      • Your pull tabs may be in different positions.
      • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. Be careful not to touch anything to the exposed adhesive.
      Ask FixBot
    9. iPhone 15 Pro Screen Installation, Prop up the screen: step 9, image 1 of 1
      • Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
      Ask FixBot
    10. iPhone 15 Pro Screen Installation, Connect the screen and ambient light sensor: step 10, image 1 of 3 iPhone 15 Pro Screen Installation, Connect the screen and ambient light sensor: step 10, image 2 of 3 iPhone 15 Pro Screen Installation, Connect the screen and ambient light sensor: step 10, image 3 of 3
      • Use your finger or the flat end of a spudger to connect the screen and ambient light sensor press connectors.
      Ask FixBot
    11. iPhone 15 Pro Screen Installation, Connect the battery: step 11, image 1 of 2 iPhone 15 Pro Screen Installation, Connect the battery: step 11, image 2 of 2
      • Use your finger or the flat end of a spudger to connect the battery press connector.
      Ask FixBot
    12. iPhone 15 Pro Screen Installation, Install the logic board cover: step 12, image 1 of 3 iPhone 15 Pro Screen Installation, Install the logic board cover: step 12, image 2 of 3 iPhone 15 Pro Screen Installation, Install the logic board cover: step 12, image 3 of 3
      Ask FixBot
    13. iPhone 15 Pro Screen Installation, Fasten the logic board cover: step 13, image 1 of 1
      • Use a Y000 screwdriver to install the six screws securing the logic board cover:
      • Four 1.6 mm‑long screws
      • Two 1.3 mm‑long screws
      Ask FixBot
    14. iPhone 15 Pro Screen Installation, Remove the final adhesive liners: step 14, image 1 of 3 iPhone 15 Pro Screen Installation, Remove the final adhesive liners: step 14, image 2 of 3 iPhone 15 Pro Screen Installation, Remove the final adhesive liners: step 14, image 3 of 3
      • Once you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing accidentally sticks to it.
      • Use tweezers to remove the two narrow liners covering the adhesive along the right, top, and bottom edges of the frame.
      Ask FixBot
    15. iPhone 15 Pro Screen Installation: step 15, image 1 of 2 iPhone 15 Pro Screen Installation: step 15, image 2 of 2
      • Without letting the screen touch the adhesive, hold the screen over the phone so you can access the final liner along the left edge of the frame.
      • Use a pair of tweezers or your fingers to remove the final liner along the left edge of the frame.
      Ask FixBot
    16. iPhone 15 Pro Screen Installation, Place the screen: step 16, image 1 of 3 iPhone 15 Pro Screen Installation, Place the screen: step 16, image 2 of 3 iPhone 15 Pro Screen Installation, Place the screen: step 16, image 3 of 3
      • Align the screen over the frame, then lower it into place.
      Ask FixBot
    17. iPhone 15 Pro Screen Installation, Press the screen: step 17, image 1 of 2 iPhone 15 Pro Screen Installation, Press the screen: step 17, image 2 of 2
      • Firmly press along the edges of the screen to engage the clips and compress the adhesive.
      Ask FixBot
    18. iPhone 15 Pro Screen Installation, Install the pentalobe screws: step 18, image 1 of 1
      • Use a P2 pentalobe screwdriver to install the two 7 mm‑long screws on either side of the charging port.
      Ask FixBot
    19. iPhone 15 Pro Screen Installation, Heat the screen: step 19, image 1 of 2 iPhone 15 Pro Screen Installation, Heat the screen: step 19, image 2 of 2
      • To help the adhesive bond, apply heat to the edges of the screen using a hair dryer or heat gun until it's hot to the touch.
      • If you have screen vise clamps, use them to strengthen the bond of the new adhesive. If not, keep reading for more ways to secure the screen.
      Ask FixBot
Finish Line
Nick Schultz
70,853 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 26
All Time: 170
