iPhone 15 Pro Max Back Glass Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 15 Pro Max Back Glass Removal, Prepare your phone for disassembly: step 1, image 1 of 2 iPhone 15 Pro Max Back Glass Removal, Prepare your phone for disassembly: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      Ask FixBot
    2. iPhone 15 Pro Max Back Glass Removal, Tape over any cracks: step 2, image 1 of 2 iPhone 15 Pro Max Back Glass Removal, Tape over any cracks: step 2, image 2 of 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Ask FixBot
    1. iPhone 15 Pro Max Back Glass Removal, Mark your opening picks: step 3, image 1 of 3 iPhone 15 Pro Max Back Glass Removal, Mark your opening picks: step 3, image 2 of 3 iPhone 15 Pro Max Back Glass Removal, Mark your opening picks: step 3, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 15 Pro Max Back Glass Removal, Remove the pentalobe screws: step 4, image 1 of 1
      • Use a P2 pentalobe driver to remove the two 7.2 mm-long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 15 Pro Max Back Glass Removal, Heat the bottom edge: step 5, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Ask FixBot
    2. iPhone 15 Pro Max Back Glass Removal, Insert an opening pick: step 6, image 1 of 3 iPhone 15 Pro Max Back Glass Removal, Insert an opening pick: step 6, image 2 of 3 iPhone 15 Pro Max Back Glass Removal, Insert an opening pick: step 6, image 3 of 3
      • Apply a suction handle to the bottom edge of the back glass.
      • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    3. iPhone 15 Pro Max Back Glass Removal, Back glass information: step 7, image 1 of 1
      • As you slice the adhesive securing the back glass in the next steps, be careful of the wireless charging cable near the volume buttons.
      Ask FixBot
    4. iPhone 15 Pro Max Back Glass Removal, Separate the bottom edge adhesive: step 8, image 1 of 3 iPhone 15 Pro Max Back Glass Removal, Separate the bottom edge adhesive: step 8, image 2 of 3 iPhone 15 Pro Max Back Glass Removal, Separate the bottom edge adhesive: step 8, image 3 of 3
      • Don't insert your opening pick deeper than 5 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
      Ask FixBot
    5. iPhone 15 Pro Max Back Glass Removal, Heat the left edge: step 9, image 1 of 1
      • Heat the left edge of the back glass until it's hot to the touch.
      Ask FixBot
    6. iPhone 15 Pro Max Back Glass Removal, Separate the left edge adhesive: step 10, image 1 of 2 iPhone 15 Pro Max Back Glass Removal, Separate the left edge adhesive: step 10, image 2 of 2
      • Don't insert your pick deeper than 5 mm along the left edge.
      • Insert a second opening pick to the left of the first one.
      • Slide this pick to the top left corner of the back glass to separate the left edge adhesive.
      • Leave this pick inserted to prevent the adhesive from resealing.
      Ask FixBot
    7. iPhone 15 Pro Max Back Glass Removal, Heat the top edge: step 11, image 1 of 1
      • Heat the top edge of the back glass until it's hot to the touch.
      Ask FixBot
    8. iPhone 15 Pro Max Back Glass Removal, Separate the top edge adhesive: step 12, image 1 of 3 iPhone 15 Pro Max Back Glass Removal, Separate the top edge adhesive: step 12, image 2 of 3 iPhone 15 Pro Max Back Glass Removal, Separate the top edge adhesive: step 12, image 3 of 3
      • Don't insert your pick deeper than 5 mm along the top edge.
      • Insert a third opening pick in the top left corner of the back glass.
      • Slide your pick to the top right corner to separate the top edge adhesive.
      • If the top edge of the back glass doesn't separate, the top clips may be stuck. Use the flat end of a spudger to press the clips inward until they release.
      Ask FixBot
    9. iPhone 15 Pro Max Back Glass Removal, Separate the top right corner adhesive: step 13, image 1 of 3 iPhone 15 Pro Max Back Glass Removal, Separate the top right corner adhesive: step 13, image 2 of 3 iPhone 15 Pro Max Back Glass Removal, Separate the top right corner adhesive: step 13, image 3 of 3
      • Don't slide your pick past the volume up button to avoid slicing the wireless charging cable.
      • Rotate your pick around the top right corner of the back glass.
      • Slide your pick to the volume up button.
      • Leave this pick in place to prevent the adhesive from resealing.
      Ask FixBot
    10. iPhone 15 Pro Max Back Glass Removal, Heat the right edge: step 14, image 1 of 1
      • Heat the right edge of the back glass until it's hot to the touch.
      Ask FixBot
    11. iPhone 15 Pro Max Back Glass Removal, Separate the right edge adhesive: step 15, image 1 of 3 iPhone 15 Pro Max Back Glass Removal, Separate the right edge adhesive: step 15, image 2 of 3 iPhone 15 Pro Max Back Glass Removal, Separate the right edge adhesive: step 15, image 3 of 3
      • Don't slide your pick past the volume down button to avoid slicing the wireless charging cable.
      • Insert a fourth opening pick at the bottom edge of the back glass.
      • Rotate your pick around the bottom right corner of the back glass.
      • Slide your pick to the volume down button.
      Ask FixBot
    12. iPhone 15 Pro Max Back Glass Removal, Swing open the back glass: step 16, image 1 of 3 iPhone 15 Pro Max Back Glass Removal, Swing open the back glass: step 16, image 2 of 3 iPhone 15 Pro Max Back Glass Removal, Swing open the back glass: step 16, image 3 of 3
      • Gently swing open the back glass over the right edge of the phone.
      • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
      • Rest the back glass against a box or similar object so it doesn't strain the cable.
      Ask FixBot
    13. iPhone 15 Pro Max Back Glass Removal, Remove the wireless charging connector cover: step 17, image 1 of 3 iPhone 15 Pro Max Back Glass Removal, Remove the wireless charging connector cover: step 17, image 2 of 3 iPhone 15 Pro Max Back Glass Removal, Remove the wireless charging connector cover: step 17, image 3 of 3
      Tool used on this step:
      Buy
      • Use a tri-point Y000 driver to remove the 1.0 mm‑long screw securing the wireless charging connector cover.
      • Use tweezers to slide the cover out of its slot on the logic board and remove it.
      Ask FixBot
    14. iPhone 15 Pro Max Back Glass Removal, Disconnect the wireless charging coil: step 18, image 1 of 2 iPhone 15 Pro Max Back Glass Removal, Disconnect the wireless charging coil: step 18, image 2 of 2
      • Use the tip of an opening pick to pry up and disconnect the wireless charging coil press connector.
      • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side.
      Ask FixBot
    15. iPhone 15 Pro Max Back Glass Removal, Remove the back glass: step 19, image 1 of 2 iPhone 15 Pro Max Back Glass Removal, Remove the back glass: step 19, image 2 of 2
      • Remove the back glass.
      Ask FixBot
To reassemble your phone, follow these instructions in reverse order.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings → General →About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Clay Eickemeyer
107,894 Reputation
472 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 16
All Time: 509
