Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement
Views: 9.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
40
Past 30 Days:
161
All Time:
9,715
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to upgrade or replace the left side M.2 solid-state drive (SSD) in a Lenovo Legion 5 Pro 16ACH6H gaming laptop. This laptop is only compatible with NVME SSDs, and is therefore not compatible with SATA SSDs.
Before you perform this repair, back up your existing SSD if possible. If you are replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Finally, be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Back cover removal: step 1, image 1 of 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Back cover removal: step 1, image 2 of 2
      • Use a Phillips screwdriver to remove the following ten screws securing the back cover to frame:
      • Six 12.7 mm PH00 screws
      • Four 4.2 mm PH00 screws
      Ask FixBot
    2. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the front clips: step 2, image 1 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the front clips: step 2, image 2 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the front clips: step 2, image 3 of 3
      • Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
      Ask FixBot
    3. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: step 3, image 1 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: step 3, image 2 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: step 3, image 3 of 3
      • Angle the pick to about 45˚.
      • Slide the pick along the front edge to release the clips securing the back cover to the frame.
      Ask FixBot
    4. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right clips: step 4, image 1 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right clips: step 4, image 2 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right clips: step 4, image 3 of 3
      • Insert the rounded edge of an opening pick between the back cover and the frame on the right edge.
      • Angle the pick to about 30˚ and slide down the right edge until you reach the plastic vents on the side.
      Ask FixBot
    5. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left clips: step 5, image 1 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left clips: step 5, image 2 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left clips: step 5, image 3 of 3
      • Repeat the same procedure on the left edge to release the clips.
      Ask FixBot
    6. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right vent clips: step 6, image 1 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right vent clips: step 6, image 2 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right vent clips: step 6, image 3 of 3
      • Position the laptop vertically so you can easily access the plastic vents.
      • Slide the rounded edge of an opening pick between the frame and the plastic vents on the right side near the USB-A port.
      • Rotate the pick so that it is positioned on top of the plastic vents.
      Ask FixBot
    7. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: step 7, image 1 of 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: step 7, image 2 of 2
      • Push the pick between the frame and plastic vents.
      • Slide the pick along the top edge of the plastic vents to release the clips.
      Ask FixBot
    8. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left vent clips: step 8, image 1 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left vent clips: step 8, image 2 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left vent clips: step 8, image 3 of 3
      • Slide the rounded edge of an opening pick between the frame and the plastic vents on the left side near the USB-C port.
      Ask FixBot
    9. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: step 9, image 1 of 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: step 9, image 2 of 2
      Ask FixBot
    10. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the back cover: step 10, image 1 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the back cover: step 10, image 2 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the back cover: step 10, image 3 of 3
      • Lift the back cover up and remove it from the chassis.
      • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
      Ask FixBot
    1. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Disconnect the battery: step 11, image 1 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Disconnect the battery: step 11, image 2 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Disconnect the battery: step 11, image 3 of 3
      • Use the pointed end of a spudger to push each side of the battery connector to loosen it.
      Ask FixBot
    2. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: step 12, image 1 of 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: step 12, image 2 of 2
      • Use the flat end of a spudger to push out and disconnect battery cable.
      Ask FixBot
    1. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Left SSD removal: step 13, image 1 of 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Left SSD removal: step 13, image 2 of 2
      • Use a Phillips screwdriver to remove the three 5.1 mm PH00 screws securing the left SSD shield to the motherboard.
      • During reassembly, make sure the hole on the top of the shield aligns with the post on the chassis.
      Ask FixBot
    2. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the SSD shield: step 14, image 1 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the SSD shield: step 14, image 2 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the SSD shield: step 14, image 3 of 3
      • Grab the SSD shield and lift up to remove it.
      Ask FixBot
    3. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: step 15, image 1 of 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: step 15, image 2 of 2
      • Use a Phillips screwdriver to remove the 2.6 mm PH1 screw securing the SSD to the motherboard.
      • The SSD will spring up to about 30˚ when the screw is removed.
      Ask FixBot
    4. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the left SSD: step 16, image 1 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the left SSD: step 16, image 2 of 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the left SSD: step 16, image 3 of 3
      • Grip the edges of the SSD near the screw indent.
      • Gently pull to remove the SSD.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo Legion answers community for help.
4 other people completed this guide.
Chayton Ritter
27,797 Reputation
105 Guides authored
1 Guide Comment
@chaytonr What's the maximum supported SSD capacity for Lenovo Legion 5 Pro 16ACH6H? I already have a 1TB SSD on the right slot but can i intall a 2TB SSD on the left slot for a total of 3TB storage?
Ayush Patel - Reply Share
Past 24 Hours: 5
Past 7 Days: 40
Past 30 Days: 161
All Time: 9,715
