ASUS Q405U RAM Replacement
    1. ASUS Q405U RAM Replacement, Back Cover: step 1, image 1 of 1
      • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
      Ask FixBot
    2. ASUS Q405U RAM Replacement: step 2, image 1 of 1
      • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
      Ask FixBot
    3. ASUS Q405U RAM Replacement: step 3, image 1 of 3 ASUS Q405U RAM Replacement: step 3, image 2 of 3 ASUS Q405U RAM Replacement: step 3, image 3 of 3
      • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
      Ask FixBot
    4. ASUS Q405U RAM Replacement: step 4, image 1 of 2 ASUS Q405U RAM Replacement: step 4, image 2 of 2
      • OPTIONAL: Additional pictures to demonstrate moving keyboard out of the way without detaching connections.
      • Lift the ribbon cable with gentle pressure, pry the ribbon away from the motherboard on the right side, then the left, then the center, prying away only a little triangle of tape at a time, applying gentle upward pressure to the tape while you loosen and pry.
      • Once you have enough slack in the three ribbons that hold the keyboard down too tightly, lift the front of the keyboard and twist counterclockwise to produce enough room to reach the screws securing the hard drive with your screwdriver.
      Ask FixBot
    1. ASUS Q405U RAM Replacement, RAM: step 5, image 1 of 1
      • Pull the metal arms out a couple of millimeters to release the RAM stick.
      • It will pop up at a 45 degree angle.
      • Slide the RAM stick from the socket on the motherboard.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Jeremiah Baselice
569 Reputation
5 Guides authored
UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 2-8, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G8
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 33
All Time: 1,782
