iPad mini 4 LTE Upper Component Bracket Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad mini 4 LTE Upper Component Bracket Replacement, Upper Component Bracket: step 1, image 1 of 2 iPad mini 4 LTE Upper Component Bracket Replacement, Upper Component Bracket: step 1, image 2 of 2
    • Run the pointed end of a spudger between the looped tape and the plastic cellular antenna housing to make it easier to peel the tape up.
  2. iPad mini 4 LTE Upper Component Bracket Replacement: step 2, image 1 of 3 iPad mini 4 LTE Upper Component Bracket Replacement: step 2, image 2 of 3 iPad mini 4 LTE Upper Component Bracket Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to peel up the looped tape adhered over the upper component cable bracket.
  3. iPad mini 4 LTE Upper Component Bracket Replacement: step 3, image 1 of 1
    • Remove the following four Phillips screws holding the upper component bracket in place:
    • Two 2.1 mm screws
    • Two 1.2 mm screws
  4. iPad mini 4 LTE Upper Component Bracket Replacement: step 4, image 1 of 1
    • Remove the upper component cable bracket.
Evan Noronha
223,680 Reputation
168 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 61
