Shop the Holiday Gift Guide
iPad Pro 9.7" Opening Display Assembly
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
10
All Time:
407
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite only guide. Shows how to swing open the Display Assembly for the iPad Pro 9.7"
Tools
    1. iPad Pro 9.7" Opening Display Assembly, Slice through the remaining adhesive: step 1, image 1 of 3 iPad Pro 9.7" Opening Display Assembly, Slice through the remaining adhesive: step 1, image 2 of 3 iPad Pro 9.7" Opening Display Assembly, Slice through the remaining adhesive: step 1, image 3 of 3
      • Use picks to ensure most of the adhesive has been cut through on the top, left, and bottom sides.
      • Twist the top and bottom picks to separate the display assembly from the rear case.
      • Do not attempt to remove the display—it is still attached to the rear case.
      Ask FixBot
    2. iPad Pro 9.7" Opening Display Assembly: step 2, image 1 of 3 iPad Pro 9.7" Opening Display Assembly: step 2, image 2 of 3 iPad Pro 9.7" Opening Display Assembly: step 2, image 3 of 3
      • Swing the display assembly towards the right of the case, using the right edge as a hinge.
      • As you move the display assembly, make sure that the display ribbon cable is not being stressed.
      • Continue swinging the display assembly until it lays flat next to the rear case.
      Ask FixBot
Author
with
Arthur Shi
353,975 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 407
