Shop the Holiday Gift Guide
iPad Pro 13" Transfer Screen Components
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
14
All Time:
154
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Parts
Tools
    1. iPad Pro 13" Transfer Screen Components, Screen components information: step 1, image 1 of 1
      • The iPad screen has multiple small components mounted to the back of it:
      • The top sensor assembly
      • Two magnets along the top edge
      • Three display cables
      • If the replacement screen includes all of these components, skip to this step. Otherwise, only transfer the missing components.
      Ask FixBot
    2. iPad Pro 13" Transfer Screen Components, Top sensor assembly information: step 2, image 1 of 2 iPad Pro 13" Transfer Screen Components, Top sensor assembly information: step 2, image 2 of 2
      • The top sensor assembly is composed of two sensors:
      • Microphone
      • Ambient light sensor
      • If your replacement screen comes with a top sensor assembly pre‑installed, skip to this step.
      Ask FixBot
    3. iPad Pro 13" Transfer Screen Components, Heat the top sensor assembly: step 3, image 1 of 1
      Ask FixBot
    4. iPad Pro 13" Transfer Screen Components, Separate the ambient light sensor: step 4, image 1 of 3 iPad Pro 13" Transfer Screen Components, Separate the ambient light sensor: step 4, image 2 of 3 iPad Pro 13" Transfer Screen Components, Separate the ambient light sensor: step 4, image 3 of 3
      • Slide an opening tool between the ambient light sensor and the screen.
      • Pry it up slowly to separate its adhesive. If it doesn't budge, apply more heat and try again.
      Ask FixBot
    5. iPad Pro 13" Transfer Screen Components, Separate the microphone: step 5, image 1 of 3 iPad Pro 13" Transfer Screen Components, Separate the microphone: step 5, image 2 of 3 iPad Pro 13" Transfer Screen Components, Separate the microphone: step 5, image 3 of 3
      • Use an opening tool to lift the microphone and separate the adhesive securing it to the screen.
      • Lift the entire top sensor assembly to separate it from the screen.
      Ask FixBot
    6. iPad Pro 13" Transfer Screen Components, Magnet information: step 6, image 1 of 2 iPad Pro 13" Transfer Screen Components, Magnet information: step 6, image 2 of 2
      • The iPad screen has two magnets along the top edge. These are used for accessories like cases.
      • If the replacement screen comes with magnets pre‑installed, skip to this step.
      • Mark the magnets with a marker so you know which orientation to install them in on the replacement screen—they won't work if installed incorrectly.
      Ask FixBot
    7. iPad Pro 13" Transfer Screen Components, Heat the magnet adhesive: step 7, image 1 of 1
      Ask FixBot
    8. iPad Pro 13" Transfer Screen Components, Remove the first magnet: step 8, image 1 of 3 iPad Pro 13" Transfer Screen Components, Remove the first magnet: step 8, image 2 of 3 iPad Pro 13" Transfer Screen Components, Remove the first magnet: step 8, image 3 of 3
      • Insert the flat end of a spudger between the raised portion of the screen and the magnet.
      • Push the magnet towards the top edge of the screen using slow, steady force until it's free.
      • Set the first magnet to the side, ensuring it remains in the same orientation.
      Ask FixBot
    9. iPad Pro 13" Transfer Screen Components, Heat the second magnet adhesive: step 9, image 1 of 1
      Ask FixBot
    10. iPad Pro 13" Transfer Screen Components, Remove the second magnet: step 10, image 1 of 3 iPad Pro 13" Transfer Screen Components, Remove the second magnet: step 10, image 2 of 3 iPad Pro 13" Transfer Screen Components, Remove the second magnet: step 10, image 3 of 3
      • Repeat this process to remove the second magnet from the screen.
      Ask FixBot
    11. iPad Pro 13" Transfer Screen Components, Screen cable information: step 11, image 1 of 1
      • The screen contains three cables on the back: one for touch, one for display, and one for power (with two press connectors).
      • The touch and display cables are modular, and need to be transferred to the replacement screen in the following steps.
      • If your replacement screen has all three cables pre‑installed, skip to this step.
      Ask FixBot
    12. iPad Pro 13" Transfer Screen Components, Remove the screen cable bracket: step 12, image 1 of 2 iPad Pro 13" Transfer Screen Components, Remove the screen cable bracket: step 12, image 2 of 2
      • Use your finger or a spudger to lift the screen's power cable off the screen cable cover.
      • Use a JCIS or JIS 00 screwdriver to remove the three 1.2 mm‑long screws screws securing the screen cable cover.
      Ask FixBot
    13. iPad Pro 13" Transfer Screen Components: step 13, image 1 of 3 iPad Pro 13" Transfer Screen Components: step 13, image 2 of 3 iPad Pro 13" Transfer Screen Components: step 13, image 3 of 3
      • Lift the screen cable bracket to a roughly 45‑degree angle and pull it off.
      Ask FixBot
    14. iPad Pro 13" Transfer Screen Components, Disconnect the touch cable: step 14, image 1 of 3 iPad Pro 13" Transfer Screen Components, Disconnect the touch cable: step 14, image 2 of 3 iPad Pro 13" Transfer Screen Components, Disconnect the touch cable: step 14, image 3 of 3
      • Fold the screen's power cable out of the way.
      • Use the point of a spudger to disconnect the screen's touch cable press connector.
      Ask FixBot
    15. iPad Pro 13" Transfer Screen Components, Remove the touch cable: step 15, image 1 of 2 iPad Pro 13" Transfer Screen Components, Remove the touch cable: step 15, image 2 of 2
      • Use tweezers or your fingers to remove the touch cable.
      Ask FixBot
    16. iPad Pro 13" Transfer Screen Components, Disconnect the display cable: step 16, image 1 of 3 iPad Pro 13" Transfer Screen Components, Disconnect the display cable: step 16, image 2 of 3 iPad Pro 13" Transfer Screen Components, Disconnect the display cable: step 16, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the display cable press connector.
      • Remove the display cable.
      Ask FixBot
    17. iPad Pro 13" Transfer Screen Components, Transfer the display cable: step 17, image 1 of 3 iPad Pro 13" Transfer Screen Components, Transfer the display cable: step 17, image 2 of 3 iPad Pro 13" Transfer Screen Components, Transfer the display cable: step 17, image 3 of 3
      • Align the display cable press connector over its socket on the replacement screen.
      • Use your finger or the flat end of a spudger to press the connector into place.
      Ask FixBot
    18. iPad Pro 13" Transfer Screen Components, Transfer the touch cable: step 18, image 1 of 3 iPad Pro 13" Transfer Screen Components, Transfer the touch cable: step 18, image 2 of 3 iPad Pro 13" Transfer Screen Components, Transfer the touch cable: step 18, image 3 of 3
      • Repeat this process to connect the touchscreen cable press connector.
      Ask FixBot
    19. iPad Pro 13" Transfer Screen Components, Install the screen cable bracket: step 19, image 1 of 3 iPad Pro 13" Transfer Screen Components, Install the screen cable bracket: step 19, image 2 of 3 iPad Pro 13" Transfer Screen Components, Install the screen cable bracket: step 19, image 3 of 3
      • Install the screen bracket at a roughly 45‑degree angle and set it onto the cables.
      Ask FixBot
    20. iPad Pro 13" Transfer Screen Components: step 20, image 1 of 1
      • Use a JCIS or JIS 00 screwdriver to install the three 1.2 mm‑long screws screws securing the screen cable cover.
      Ask FixBot
    21. iPad Pro 13" Transfer Screen Components: step 21, image 1 of 2 iPad Pro 13" Transfer Screen Components: step 21, image 2 of 2
      • Fold the power cable down so it sits on top of the screen cable cover.
      Ask FixBot
    22. iPad Pro 13" Transfer Screen Components, Install magnet adhesive: step 22, image 1 of 3 iPad Pro 13" Transfer Screen Components, Install magnet adhesive: step 22, image 2 of 3 iPad Pro 13" Transfer Screen Components, Install magnet adhesive: step 22, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      Ask FixBot
    23. iPad Pro 13" Transfer Screen Components, Install the first magnet: step 23, image 1 of 2 iPad Pro 13" Transfer Screen Components, Install the first magnet: step 23, image 2 of 2
      • Use a marker to mark 23 mm from the left edge and 2 mm from the top edge of the screen.
      Ask FixBot
    24. iPad Pro 13" Transfer Screen Components: step 24, image 1 of 3 iPad Pro 13" Transfer Screen Components: step 24, image 2 of 3 iPad Pro 13" Transfer Screen Components: step 24, image 3 of 3
      • Remove the adhesive backing from the first magnet.
      • Align the first magnet with the marks you made in the last step, and set it into place.
      • Press on the magnet with your finger to help the adhesive bond.
      Ask FixBot
    25. iPad Pro 13" Transfer Screen Components, Install the second magnet: step 25, image 1 of 2 iPad Pro 13" Transfer Screen Components, Install the second magnet: step 25, image 2 of 2
      • Repeat this process to install the second magnet 46 mm from the right edge and 2 mm from the top edge of the screen.
      Ask FixBot
    26. iPad Pro 13" Transfer Screen Components, Adhere the magnets: step 26, image 1 of 2 iPad Pro 13" Transfer Screen Components, Adhere the magnets: step 26, image 2 of 2
      • Heat an iOpener and set it on top of both magnets for two minutes. This will help the adhesive bond.
      • You can also use a hair dryer or heat gun to lightly heat each magnet to help the adhesive bond.
      Ask FixBot
    27. iPad Pro 13" Transfer Screen Components, Prepare the front sensor assembly: step 27, image 1 of 1
      Tesa 61395 Tape
      $2.95
      Buy
      • Use tweezers to reposition any adhesive that may have covered the ambient light sensor (white circle) or microphone (black mesh). The adhesive should go around the sensors, not cover them.
      • If the adhesive was damaged or stayed with the old screen, replace it with a 1 mm wide strip of thin, double-sided tape along the sensor's bottom border.
      Ask FixBot
    28. iPad Pro 13" Transfer Screen Components, Install the front sensor assembly: step 28, image 1 of 3 iPad Pro 13" Transfer Screen Components, Install the front sensor assembly: step 28, image 2 of 3 iPad Pro 13" Transfer Screen Components, Install the front sensor assembly: step 28, image 3 of 3
      • If you applied fresh adhesive, or if your part came with new adhesive, remove the liners now.
      • Align the microphone and ambient light sensor with their cutouts in the screen.
      • Press the microphone and ambient light sensor down for 10 seconds each to give the adhesive time to bond.
      Ask FixBot
Finish Line
Nick Schultz
70,853 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 14
All Time: 154
