Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Spudger4.9
Use a heated iOpener, hair dryer, or heat gun to soften the adhesive securing the long, black rubber cover below the front camera assembly.
Use tweezers or your fingers to pry up and remove the cover from the right side. Work slowly to avoid tearing it—it'll be reused later.
Use a JCIS or JIS 00 screwdriver to remove the four screws securing the front camera bracket:
Two 2.0 mm‑long screws on either edge.
Two 1.3 mm‑long screws in the center of the bracket.
Use the point of a spudger to pry up and disconnect the front camera module's leftmost press connector.
Use a Torx Plus 3IP screwdriver to remove the two 2.0 mm‑long screws securing the front camera assembly.
Use your fingers or a spudger to pry up and remove the front camera assembly from its right edge.
