Shop the Holiday Gift Guide
iPad Pro 13" Front Camera Installation
View statistics:
Past 24 Hours:
3
Past 7 Days:
6
Past 30 Days:
12
All Time:
98
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. iPad Pro 13" Front Camera Installation, Remove residue: step 1, image 1 of 3 iPad Pro 13" Front Camera Installation, Remove residue: step 1, image 2 of 3 iPad Pro 13" Front Camera Installation, Remove residue: step 1, image 3 of 3
      • Be careful not to damage the press connector sockets when cleaning around them.
      • Use the point of a spudger to lift any residual adhesive from between and around the front camera press connector sockets.
      • Use tweezers to remove the residual adhesive.
      Ask FixBot
    2. iPad Pro 13" Front Camera Installation, Install the front camera module: step 2, image 1 of 3 iPad Pro 13" Front Camera Installation, Install the front camera module: step 2, image 2 of 3 iPad Pro 13" Front Camera Installation, Install the front camera module: step 2, image 3 of 3
      • Be careful not to touch the camera lenses—they're extremely difficult to clean.
      • If the replacement part includes protective covers over the camera lenses, leave them in place until this step.
      • Set the front camera module into its recess in the frame.
      Ask FixBot
    3. iPad Pro 13" Front Camera Installation: step 3, image 1 of 1
      • Use a JCIS or JIS 00 screwdriver to install the two 2.0 mm‑long screws securing the front camera module.
      Ask FixBot
    4. iPad Pro 13" Front Camera Installation, Connect the front camera module: step 4, image 1 of 3 iPad Pro 13" Front Camera Installation, Connect the front camera module: step 4, image 2 of 3 iPad Pro 13" Front Camera Installation, Connect the front camera module: step 4, image 3 of 3
      • Use the flat end of a spudger or your finger to connect the front camera module's two central press connectors.
      Ask FixBot
    5. iPad Pro 13" Front Camera Installation: step 5, image 1 of 2 iPad Pro 13" Front Camera Installation: step 5, image 2 of 2
      • Repeat the previous step to connect the front camera module's leftmost press connector.
      Ask FixBot
    6. iPad Pro 13" Front Camera Installation, Install the front camera bracket: step 6, image 1 of 2 iPad Pro 13" Front Camera Installation, Install the front camera bracket: step 6, image 2 of 2
      • Align the front camera module bracket with its screw holes and set it into place.
      Ask FixBot
    7. iPad Pro 13" Front Camera Installation: step 7, image 1 of 1
      • Use a JCIS or JIS 00 screwdriver to install the four screws securing the front camera bracket:
      • Two 2.0 mm‑long screws on either edge.
      • The left edge screw hole is hidden by the black rubber cover. Peel up only the loose portion on its left edge to install it.
      • Two 1.3 mm‑long screws in the center of the bracket.
      Ask FixBot
    8. iPad Pro 13" Front Camera Installation, Install the bracket cover: step 8, image 1 of 2 iPad Pro 13" Front Camera Installation, Install the bracket cover: step 8, image 2 of 2
      • Align the black rubber cover over the front camera module's bracket.
      • Press the cover onto the front camera module's bracket. Be careful not to touch the camera lenses.
      • Use an heated iOpener, hair dryer, or heat gun to soften the adhesive securing cover and help it bond.
      Ask FixBot
Finish Line
Nick Schultz
70,853 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 12
All Time: 98
