Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Community-Contributed Guide
Introduction
Go to step 1 ↓The official guide has been updated and can be found here. This guide is archived for historical purposes.
Couldn't find a guide to fix a customer’s iPad so here it is put a lot of work into providing something you can use as a reference! Thanks, comment please!
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Be sure to turn off the iPad by pressing and releasing the volume up button then volume down.
Press and hold the side button until the screen turns off.
Use the slider if you can.
Remove PH000 Battery Connection clip retaining screw.
Move Small cable is taped around edges up so you can gain access to the side of the battery connection.
Slide thin plastic under battery connection. This will lift the battery connection pins away from the battery cable connectors and isolate the battery.
Remove all 3 ribbon cables from logic board with flat headed spudger!
