iPad Mini CDMA Small Metal Bracket Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad Mini CDMA Small Metal Bracket Replacement, Small Metal Bracket: step 1, image 1 of 3 iPad Mini CDMA Small Metal Bracket Replacement, Small Metal Bracket: step 1, image 2 of 3 iPad Mini CDMA Small Metal Bracket Replacement, Small Metal Bracket: step 1, image 3 of 3
    • Use the tip of a spudger to start peeling up the right side of the black tape covering the small metal bracket.
    • Peel the tape up the rest of the way with tweezers, and remove it from the bracket.
  2. iPad Mini CDMA Small Metal Bracket Replacement: step 2, image 1 of 2 iPad Mini CDMA Small Metal Bracket Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to push the metal bracket slightly to the left.
  3. iPad Mini CDMA Small Metal Bracket Replacement: step 3, image 1 of 2 iPad Mini CDMA Small Metal Bracket Replacement: step 3, image 2 of 2
    • Use the tip of a spudger to lift up the lower side of the metal bracket.
  4. iPad Mini CDMA Small Metal Bracket Replacement: step 4, image 1 of 2 iPad Mini CDMA Small Metal Bracket Replacement: step 4, image 2 of 2
    • Grab the bracket with tweezers and lift it up out of the iPad.
    • During reassembly, hook the top edge of the plate in place first, then lower the bottom into its slots.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 131
