iPad Mini CDMA Small Metal Bracket Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPad Mini CDMA Small Metal Bracket Replacement, Small Metal Bracket: step 1, image 1 of 3 iPad Mini CDMA Small Metal Bracket Replacement, Small Metal Bracket: step 1, image 2 of 3 iPad Mini CDMA Small Metal Bracket Replacement, Small Metal Bracket: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Use the tip of a spudger to start peeling up the right side of the black tape covering the small metal bracket.
      • Peel the tape up the rest of the way with tweezers, and remove it from the bracket.
      Ask FixBot
    2. iPad Mini CDMA Small Metal Bracket Replacement: step 2, image 1 of 2 iPad Mini CDMA Small Metal Bracket Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to push the metal bracket slightly to the left.
      Ask FixBot
    3. iPad Mini CDMA Small Metal Bracket Replacement: step 3, image 1 of 2 iPad Mini CDMA Small Metal Bracket Replacement: step 3, image 2 of 2
      • Use the tip of a spudger to lift up the lower side of the metal bracket.
      Ask FixBot
    4. iPad Mini CDMA Small Metal Bracket Replacement: step 4, image 1 of 2 iPad Mini CDMA Small Metal Bracket Replacement: step 4, image 2 of 2
      • Grab the bracket with tweezers and lift it up out of the iPad.
      • During reassembly, hook the top edge of the plate in place first, then lower the bottom into its slots.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 24
All Time: 470
