iPad Mini 3 Left Antenna Cable Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad Mini 3 Left Antenna Cable Replacement, Left Antenna Cable: step 1, image 1 of 3 iPad Mini 3 Left Antenna Cable Replacement, Left Antenna Cable: step 1, image 2 of 3 iPad Mini 3 Left Antenna Cable Replacement, Left Antenna Cable: step 1, image 3 of 3
    • Pull the wide tape toward the battery, applying constant force to peel it from the antenna cable lodged between it and the speaker.
    • Insert a plastic opening tool into the gap between the wide tape and the antenna cable, to break the adhesive connecting the two.
    • Slide the plastic opening tool along the length of the antenna cable to completely separate it from the piece of tape.
  2. iPad Mini 3 Left Antenna Cable Replacement: step 2, image 1 of 3 iPad Mini 3 Left Antenna Cable Replacement: step 2, image 2 of 3 iPad Mini 3 Left Antenna Cable Replacement: step 2, image 3 of 3
    • Lift the antenna cable tape up from behind the right speaker.
  3. iPad Mini 3 Left Antenna Cable Replacement: step 3, image 1 of 2 iPad Mini 3 Left Antenna Cable Replacement: step 3, image 2 of 2
    • Pull the antenna cable out from under the corner of the right speaker.
Sam Goldheart
465,970 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,299 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 78
