You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Prereq only.
Parts
No parts specified.
  1. Pull the wide tape toward the battery, applying constant force to peel it from the antenna cable lodged between it and the speaker. Insert a plastic opening tool into the gap between the wide tape and the antenna cable, to break the adhesive connecting the two. Slide the plastic opening tool along the length of the antenna cable to completely separate it from the piece of tape.
    • Pull the wide tape toward the battery, applying constant force to peel it from the antenna cable lodged between it and the speaker.
    • Insert a plastic opening tool into the gap between the wide tape and the antenna cable, to break the adhesive connecting the two.
    • Slide the plastic opening tool along the length of the antenna cable to completely separate it from the piece of tape.
  2. Lift the antenna cable tape up from behind the right speaker. Lift the antenna cable tape up from behind the right speaker. Lift the antenna cable tape up from behind the right speaker.
    • Lift the antenna cable tape up from behind the right speaker.
  3. Pull the antenna cable out from under the corner of the right speaker. Pull the antenna cable out from under the corner of the right speaker.
    • Pull the antenna cable out from under the corner of the right speaker.
Sam Goldheart
440,716 Reputation
547 Guides authored
iFixit Member of iFixit
Community
136 Members
16,682 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 48
