iPad 4 Wi-Fi Headphone Jack Cable Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad 4 Wi-Fi Headphone Jack Cable Replacement, Headphone Jack Cable: step 1, image 1 of 3 iPad 4 Wi-Fi Headphone Jack Cable Replacement, Headphone Jack Cable: step 1, image 2 of 3 iPad 4 Wi-Fi Headphone Jack Cable Replacement, Headphone Jack Cable: step 1, image 3 of 3
    • Use tweezers to peel back and remove the piece of electrical tape covering the headphone jack assembly cable connector.
    • Using the tip of a spudger, flip up the retaining flap on both of the ZIF connectors securing the headphone jack cable to the logic board.
  2. iPad 4 Wi-Fi Headphone Jack Cable Replacement: step 2, image 1 of 2 iPad 4 Wi-Fi Headphone Jack Cable Replacement: step 2, image 2 of 2
    • Slide the flat end of a spudger underneath the headphone jack assembly cable, releasing the adhesive securing it to the rear aluminum frame.
    • Pull the headphone jack assembly cable straight out of its socket on the logic board.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 48
