iPad 3 4G Front Panel Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad 3 4G Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 1 of 1
    • Remove the four 2 mm Phillips #00 screws securing the LCD to the aluminum frame.
  2. iPad 3 4G Front Panel Assembly Replacement: step 2, image 1 of 3 iPad 3 4G Front Panel Assembly Replacement: step 2, image 2 of 3 iPad 3 4G Front Panel Assembly Replacement: step 2, image 3 of 3
    • Using a plastic opening tool or a spudger, lift the right edge of the LCD out of the iPad.
    • Rotate the LCD along its left edge and lay it down on top of the front panel.
    • Be careful as you move the LCD. The ribbon cable is fragile and may break if it is flexed too much.
Brett Hartt
127,980 Reputation
143 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,439 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 506
