iPad 2 Wi-Fi EMC 2415 LCD Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad 2 Wi-Fi EMC 2415 LCD Replacement, LCD: step 1, image 1 of 1
    • Remove the four 2.0 mm Phillips screws securing the LCD to the rear case.
  2. iPad 2 Wi-Fi EMC 2415 LCD Replacement: step 2, image 1 of 2 iPad 2 Wi-Fi EMC 2415 LCD Replacement: step 2, image 2 of 2
    • The front panel ribbon cables are connected beneath the LCD. To access them, you'll need to temporarily flip the LCD over and out of the way.
    • Be very careful when moving the LCD, and do not attempt to remove it from the iPad—its display data cable will remain connected while it is rotated over.
    • Lift the LCD from its long edge closest to the volume buttons and gently flip it out of the rear case—like turning the page in a book.
    • Set the LCD face down on the front panel.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 601
