Shop the Holiday Gift Guide
iPad 10 Digitizer Installation
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
8
All Time:
97
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite only guide to install the digitizer in an iPad 10.
Parts
Tools
    1. iPad 10 Digitizer Installation, Clean the frame adhesive: step 1, image 1 of 2 iPad 10 Digitizer Installation, Clean the frame adhesive: step 1, image 2 of 2
      • Don't touch the ambient light sensor or selfie camera along the top edge of the iPad while cleaning the frame.
      • Use a hair dryer or heat gun to heat a roughly 3 inch (~8 cm) section of the frame edge.
      Ask FixBot
    2. iPad 10 Digitizer Installation: step 2, image 1 of 2 iPad 10 Digitizer Installation: step 2, image 2 of 2
      • Use an opening tool to scrape the old adhesive into a ball on the section of the frame you heated.
      • Use tweezers to remove the balled up adhesive.
      • Repeat this heating and scraping process until most of the old adhesive is removed from the frame.
      Ask FixBot
    3. iPad 10 Digitizer Installation: step 3, image 1 of 3 iPad 10 Digitizer Installation: step 3, image 2 of 3 iPad 10 Digitizer Installation: step 3, image 3 of 3
      Tool used on this step:
      Adhesive Cleanup Kit (Set of 12)
      $7.99
      Buy
      • Apply a bit of isopropyl alcohol to a cotton swab or lint-free cloth and clean the frame until it's free of adhesive residue.
      • Alternatively, use our adhesive cleanup kit.
      Ask FixBot
    4. iPad 10 Digitizer Installation, Clean the digitizer adhesive: step 4, image 1 of 3 iPad 10 Digitizer Installation, Clean the digitizer adhesive: step 4, image 2 of 3 iPad 10 Digitizer Installation, Clean the digitizer adhesive: step 4, image 3 of 3
      • Skip this step if you're installing a new digitizer.
      • Repeat this process to clean the adhesive off the digitizer bezel. Use tweezers to get any large pieces off before using the opening tool.
      • Don't scrape too hard, or you'll scratch the digitizer's black paint.
      • Solvents (like isopropyl alcohol) will dissolve the foam gasket surrounding the clear glass. Only apply solvents to the black bezel.
      Ask FixBot
    5. iPad 10 Digitizer Installation, Align the adhesive: step 5, image 1 of 2 iPad 10 Digitizer Installation, Align the adhesive: step 5, image 2 of 2
      • If your replacement digitizer comes with adhesive pre‑installed, skip the next four steps.
      • Be careful not to crease or stretch the adhesive during installation. It can't be used if damaged.
      • Before removing any liners, align each adhesive strip over the digitizer to see where it goes. It's easiest to align the strip on the edge with the camera cutout.
      Ask FixBot
    6. iPad 10 Digitizer Installation, Remove the first adhesive liner: step 6, image 1 of 3 iPad 10 Digitizer Installation, Remove the first adhesive liner: step 6, image 2 of 3 iPad 10 Digitizer Installation, Remove the first adhesive liner: step 6, image 3 of 3
      • Remove the large liners from one of the long adhesive strips. The adhesive is now exposed.
      Ask FixBot
    7. iPad 10 Digitizer Installation, Install the adhesive: step 7, image 1 of 3 iPad 10 Digitizer Installation, Install the adhesive: step 7, image 2 of 3 iPad 10 Digitizer Installation, Install the adhesive: step 7, image 3 of 3
      • Work slowly when installing the adhesive—once it sticks, it can't be repositioned.
      • Install one of the large adhesive strips to the back of the digitizer.
      • Check the adhesive to make sure it doesn't overhang the edge of the digitizer glass. If it does, remove it and start over with new adhesive.
      Ask FixBot
    8. iPad 10 Digitizer Installation: step 8, image 1 of 3 iPad 10 Digitizer Installation: step 8, image 2 of 3 iPad 10 Digitizer Installation: step 8, image 3 of 3
      • Repeat this process to install the remaining two adhesive strips.
      Ask FixBot
    9. iPad 10 Digitizer Installation, Prop up the digitizer: step 9, image 1 of 1
      • Set the digitizer on the frame of the iPad, so the cables can reach their connectors on the board.
      • Lean the digitizer against a large, sturdy object to keep it upright.
      Ask FixBot
    10. iPad 10 Digitizer Installation, Connect the digitizer: step 10, image 1 of 3 iPad 10 Digitizer Installation, Connect the digitizer: step 10, image 2 of 3 iPad 10 Digitizer Installation, Connect the digitizer: step 10, image 3 of 3
      • Use your finger or the flat end of a spudger to connect the three digitizer press connectors to their respective sockets on the board.
      Ask FixBot
    11. iPad 10 Digitizer Installation, Install the digitizer connector covers: step 11, image 1 of 3 iPad 10 Digitizer Installation, Install the digitizer connector covers: step 11, image 2 of 3 iPad 10 Digitizer Installation, Install the digitizer connector covers: step 11, image 3 of 3
      • Set the two digitizer connector covers over their respective connectors on the board.
      Ask FixBot
    12. iPad 10 Digitizer Installation: step 12, image 1 of 1
      • Use a JIS 00 screwdriver to install the four 1.1 mm‑long screws securing the digitizer connector covers.
      Ask FixBot
    13. iPad 10 Digitizer Installation, Set the screen into place: step 13, image 1 of 1
      • Don't touch the front of the screen with your fingers. Any oils will be difficult to remove.
      • Set the screen on the iPad, so the screen cable connector can reach its socket on the board.
      Ask FixBot
    14. iPad 10 Digitizer Installation, Connect the screen: step 14, image 1 of 3 iPad 10 Digitizer Installation, Connect the screen: step 14, image 2 of 3 iPad 10 Digitizer Installation, Connect the screen: step 14, image 3 of 3
      • Use your finger to connect the screen connector to its socket on the board.
      • Press the screen cable down so it sits flat onto the board.
      Ask FixBot
    15. iPad 10 Digitizer Installation, Install the display connector cover: step 15, image 1 of 2 iPad 10 Digitizer Installation, Install the display connector cover: step 15, image 2 of 2
      • Set the display connector cover into place, aligned with its screw posts.
      Ask FixBot
    16. iPad 10 Digitizer Installation: step 16, image 1 of 1
      • Use a JIS 00 screwdriver to install the two 1.1 mm‑long screws securing the display connector cover.
      Ask FixBot
    17. iPad 10 Digitizer Installation, Lay the screen into place: step 17, image 1 of 3 iPad 10 Digitizer Installation, Lay the screen into place: step 17, image 2 of 3 iPad 10 Digitizer Installation, Lay the screen into place: step 17, image 3 of 3
      • Lower the screen into its recess.
      Ask FixBot
    18. iPad 10 Digitizer Installation, Install the display screws: step 18, image 1 of 1
      • Use a Torx Plus 2IP screwdriver to install the ten screws securing the iPad display:
      • Four 3.5 mm‑long screws
      • Six 3.2 mm‑long screws
      • In cellular models, use a JIS 00 screwdriver to remove the additional screws along the right edge.
      Ask FixBot
    19. iPad 10 Digitizer Installation, Remove the adhesive liners: step 19, image 1 of 3 iPad 10 Digitizer Installation, Remove the adhesive liners: step 19, image 2 of 3 iPad 10 Digitizer Installation, Remove the adhesive liners: step 19, image 3 of 3
      • Use tweezers or your fingers to remove the top blue liner off the iPad digitizer adhesive.
      Ask FixBot
    20. iPad 10 Digitizer Installation: step 20, image 1 of 2 iPad 10 Digitizer Installation: step 20, image 2 of 2
      • Use tweezers or your fingers to remove the blue liner on the left edge of the digitizer adhesive.
      Ask FixBot
    21. iPad 10 Digitizer Installation: step 21, image 1 of 3 iPad 10 Digitizer Installation: step 21, image 2 of 3 iPad 10 Digitizer Installation: step 21, image 3 of 3
      • Lower the digitizer until you can access the final blue liner.
      • Use tweezers or your fingers to peel the final blue liner off the last adhesive strip.
      Ask FixBot
    22. iPad 10 Digitizer Installation, Install the digitizer: step 22, image 1 of 3 iPad 10 Digitizer Installation, Install the digitizer: step 22, image 2 of 3 iPad 10 Digitizer Installation, Install the digitizer: step 22, image 3 of 3
      • Lower the digitizer into place.
      • Press along the edges of the digitizer so it sits flush into the iPad frame.
      Ask FixBot
    23. iPad 10 Digitizer Installation, Press the screen adhesive: step 23, image 1 of 2 iPad 10 Digitizer Installation, Press the screen adhesive: step 23, image 2 of 2
      • In order for the adhesive to bond correctly, you'll need to apply even pressure around the perimeter of the iPad. You can compensate for the camera bump by laying the iPad face-down and placing coins around its perimeter.
      • Alternatively, you can use screen vise clamps around the perimeter of your device to set the new adhesive.
      • Place the iPad screen-side-down on a soft, flat surface.
      • Apply painter's tape to the back to protect its finish.
      Ask FixBot
    24. iPad 10 Digitizer Installation: step 24, image 1 of 2 iPad 10 Digitizer Installation: step 24, image 2 of 2
      • Place evenly spaced layers of coins or similarly thick objects on the tape along the edges of the back glass.
      • Stack them to a consistent height taller than the camera bump.
      Ask FixBot
    25. iPad 10 Digitizer Installation: step 25, image 1 of 1
      • Stack multiple books or other heavy objects on the iPad.
      • The coins may leave an impression on the bottom object, so don't use anything valuable.
      • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
      Ask FixBot
Finish Line
Nick Schultz
70,853 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 97
