iMac Whiteboard
  1. iMac Whiteboard, iMac Whiteboard: step 1, image 1 of 1
    • We start up with an empty case of an iMac.
  2. iMac Whiteboard: step 2, image 1 of 1
    • Unscrew the case and take the 56x35 whiteboard, check that it fits nicely.
  3. iMac Whiteboard: step 3, image 1 of 1
    • Apply contact cement to the inside borders of the front case. Leave to dry for about 5 minutes.
  4. iMac Whiteboard: step 4, image 1 of 1
    • Place the whiteboard onto the front case and put weight on it.
    • Make sure that the whiteboard touches the lower side of the metal panel.
    • Leave to dry out for a day.
  5. iMac Whiteboard: step 5, image 1 of 2 iMac Whiteboard: step 5, image 2 of 2
    • Mark up 4 lines of 4cm each on the cardbox.
    • Cut up a rectangle and fold to make up a cilinder. Use scotch tape to hold them together.
    • Repeat to get 2 more cilinders.
  6. iMac Whiteboard: step 6, image 1 of 1
    • Glue the cilinders to the back case of the iMac.
    • This is to have some pressure against the whiteboard.
  7. iMac Whiteboard: step 7, image 1 of 1
    • After the contact cement has dried, take out the small contact cement remnants from the board with a cardbox cutter and a plastic tool (as to not damage the whiteboard)
  8. iMac Whiteboard: step 8, image 1 of 1
    • Reassemble your iMac and write something on it.
Angela Penaherrera
12,574 Reputation
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 28
All Time: 8,133
