iMac Intel 27" EMC 2546 Heat Sink Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iMac Intel 27" EMC 2546 Heat Sink Replacement, Heat Sink: step 1, image 1 of 3 iMac Intel 27" EMC 2546 Heat Sink Replacement, Heat Sink: step 1, image 2 of 3 iMac Intel 27" EMC 2546 Heat Sink Replacement, Heat Sink: step 1, image 3 of 3
    • Remove the four 7.5 mm T8 screws from behind the GPU on the logic board.
    • These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T8 screws, hold them with a fingertip or Phillips #2 screwdriver.
  2. iMac Intel 27" EMC 2546 Heat Sink Replacement: step 2, image 1 of 1
    • Remove the bracket from behind the GPU heat sink.
  3. iMac Intel 27" EMC 2546 Heat Sink Replacement: step 3, image 1 of 1
    • Remove four black stickers from the back of the CPU heat sink.
  4. iMac Intel 27" EMC 2546 Heat Sink Replacement: step 4, image 1 of 1
    • Remove four 12.3 mm T10 screws from the back of the CPU heat sink.
  5. iMac Intel 27" EMC 2546 Heat Sink Replacement: step 5, image 1 of 3 iMac Intel 27" EMC 2546 Heat Sink Replacement: step 5, image 2 of 3 iMac Intel 27" EMC 2546 Heat Sink Replacement: step 5, image 3 of 3
    • Remove the spring plate from behind the CPU heat sink.
    • Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board.
  6. iMac Intel 27" EMC 2546 Heat Sink Replacement: step 6, image 1 of 3 iMac Intel 27" EMC 2546 Heat Sink Replacement: step 6, image 2 of 3 iMac Intel 27" EMC 2546 Heat Sink Replacement: step 6, image 3 of 3
    • Lift the heat sink up from the logic board.
    • The CPU will most likely stick to the heat sink, so be careful about where you put it down.
Andrew Optimus Goldheart
503,290 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 209
