Remove the four 7.5 mm T9 screws from behind the GPU on the logic board.
These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T9 screws, hold them with a fingertip or Phillips #2 screwdriver.
