iMac Intel 24" EMC 2134 and 2211 RAM Replacement
  1. iMac Intel 24" EMC 2134 and 2211 RAM Replacement, Access Door: step 1, image 1 of 1
    • Loosen the single Phillips screw in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
  2. iMac Intel 24" EMC 2134 and 2211 RAM Replacement, RAM: step 2, image 1 of 2 iMac Intel 24" EMC 2134 and 2211 RAM Replacement, RAM: step 2, image 2 of 2
    • Use the tip of a spudger to pull the black plastic RAM tabs out of the memory bay.
    • Pull the black plastic RAM tab away from your iMac to eject the RAM module.
  3. iMac Intel 24" EMC 2134 and 2211 RAM Replacement: step 3, image 1 of 1
    • Grab the RAM module by its edges and pull it straight out of its slot.
    • If two RAM modules are installed, repeat this process for the other chip.
Brittany McCrigler
89,017 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,199 Guides authored
Past 24 Hours: 2
Past 7 Days: 33
Past 30 Days: 102
All Time: 38,567
