Installing iMac G4 17 800 MHz EMC 1936 Battery
  1. Installing iMac G4 17 800 MHz EMC 1936  Battery, Battery: step 1, image 1 of 3 Installing iMac G4 17 800 MHz EMC 1936  Battery, Battery: step 1, image 2 of 3 Installing iMac G4 17 800 MHz EMC 1936  Battery, Battery: step 1, image 3 of 3
    • G4 bottom Plate with four captive Phillips screws
    • The bottom of the plate will list the serial number, MHz of the machine, standard RAM and hard drive size
  2. Installing iMac G4 17 800 MHz EMC 1936  Battery: step 2, image 1 of 1
    • Here the plate has been removed exposing the slot for the Airport Card and User added RAM slot.
  3. Installing iMac G4 17 800 MHz EMC 1936  Battery: step 3, image 1 of 2 Installing iMac G4 17 800 MHz EMC 1936  Battery: step 3, image 2 of 2
    • Remove the four T15 torx screws.
    • Set the unit on it's base, grasp the neck and tilt it to separate the base.
  4. Installing iMac G4 17 800 MHz EMC 1936  Battery: step 4, image 1 of 2 Installing iMac G4 17 800 MHz EMC 1936  Battery: step 4, image 2 of 2
    • The IDE cable unplugs first.
    • Locate the 3.6 volt 1/2 AA Lithium PRAM battery on the logic board and replace it.
mayer
685,367 Reputation
12 Guides authored
MacHale Enterprises Member of MacHale Enterprises
Business
1 Member
18 Guides authored
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 42
All Time: 15,289
