Installing iMac G3 Model M4984 Logic Board
  1. Installing iMac G3 Model M4984 Logic Board, Logic Board: step 1, image 1 of 1
    • The iMac G3. This was a great computer for the time, and had plenty of features.
  2. Installing iMac G3 Model M4984 Logic Board: step 2, image 1 of 1
    • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
  3. Installing iMac G3 Model M4984 Logic Board: step 3, image 1 of 3 Installing iMac G3 Model M4984 Logic Board: step 3, image 2 of 3 Installing iMac G3 Model M4984 Logic Board: step 3, image 3 of 3
    • Remove this Phillips screw.
    • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
    • Then, lift the bottom cover up and out, and set it aside.
  4. Installing iMac G3 Model M4984 Logic Board: step 4, image 1 of 3 Installing iMac G3 Model M4984 Logic Board: step 4, image 2 of 3 Installing iMac G3 Model M4984 Logic Board: step 4, image 3 of 3
    • Now, remove the DB-15 Video connector from the logic board.
    • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
  5. Installing iMac G3 Model M4984 Logic Board: step 5, image 1 of 3 Installing iMac G3 Model M4984 Logic Board: step 5, image 2 of 3 Installing iMac G3 Model M4984 Logic Board: step 5, image 3 of 3
    • Remove the power cable from the logic board assembly.
  6. Installing iMac G3 Model M4984 Logic Board: step 6, image 1 of 2 Installing iMac G3 Model M4984 Logic Board: step 6, image 2 of 2
    • Remove the front panel connector.
  7. Installing iMac G3 Model M4984 Logic Board: step 7, image 1 of 3 Installing iMac G3 Model M4984 Logic Board: step 7, image 2 of 3 Installing iMac G3 Model M4984 Logic Board: step 7, image 3 of 3
    • Now, remove these Phillips screws.
    • Now, grab the logic board assembly by the piece of plastic, and lift it out.
  8. Installing iMac G3 Model M4984 Logic Board: step 8, image 1 of 1
    • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
Chris Green
37,065 Reputation
49 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,490 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 46
All Time: 18,584
