iFixit Digital Multimeter Outer Cover Replacement
    1. iFixit Digital Multimeter Outer Cover Replacement, Turn off your multimeter: step 1, image 1 of 2 iFixit Digital Multimeter Outer Cover Replacement, Turn off your multimeter: step 1, image 2 of 2
      • Turn off your multimeter.
      • Disconnect the probes from your multimeter.
      Ask FixBot
    1. iFixit Digital Multimeter Outer Cover Replacement, Loosen the cover edges: step 2, image 1 of 3 iFixit Digital Multimeter Outer Cover Replacement, Loosen the cover edges: step 2, image 2 of 3 iFixit Digital Multimeter Outer Cover Replacement, Loosen the cover edges: step 2, image 3 of 3
      • Use your fingers to pull and loosen the cover lip out of its groove along the right edge of the multimeter.
      • Pry and loosen the cover from the bottom right corner of the multimeter.
      Ask FixBot
    2. iFixit Digital Multimeter Outer Cover Replacement: step 3, image 1 of 3 iFixit Digital Multimeter Outer Cover Replacement: step 3, image 2 of 3 iFixit Digital Multimeter Outer Cover Replacement: step 3, image 3 of 3
      • Repeat the procedure to loosen the cover from the left edge of the multimeter.
      Ask FixBot
    3. iFixit Digital Multimeter Outer Cover Replacement: step 4, image 1 of 2 iFixit Digital Multimeter Outer Cover Replacement: step 4, image 2 of 2
      • Pull the bottom of the cover away from the multimeter to loosen it.
      Ask FixBot
    4. iFixit Digital Multimeter Outer Cover Replacement, Remove the cover: step 5, image 1 of 3 iFixit Digital Multimeter Outer Cover Replacement, Remove the cover: step 5, image 2 of 3 iFixit Digital Multimeter Outer Cover Replacement, Remove the cover: step 5, image 3 of 3
      • Grasp the sides of the cover near the top to hold it in place.
      • Grasp the bottom edge of the multimeter and pull it out at a shallow angle to remove it from the cover.
      • During reassembly, follow this guide to properly clip the cover back in place.
      Ask FixBot
For more information on how to use your iFixit multimeter, check out this page.
Arthur Shi
351,154 Reputation
937 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,803 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 60
All Time: 396
