iBook G3 14" LCD Cover Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iBook G3 14" LCD Cover Replacement, LCD Cover: step 1, image 1 of 2 iBook G3 14" LCD Cover Replacement, LCD Cover: step 1, image 2 of 2
    • Remove the pieces of readily removable tape from around the perimeter of the display.
    • Carefully remove the aluminum tape covering the display data cable connection.
  2. iBook G3 14" LCD Cover Replacement: step 2, image 1 of 2 iBook G3 14" LCD Cover Replacement: step 2, image 2 of 2
    • Remove the single screw inserted through the piece of EMI tape near the bottom edge of the display.
    • Use the tip of a spudger to remove the small washer under the screw you just removed.
  3. iBook G3 14" LCD Cover Replacement: step 3, image 1 of 1
    • Peel the aluminum/EMI tape off the cast aluminum frame of the clutch hinges.
    • It is not necessary to peel the tape off the thin steel LCD cover.
  4. iBook G3 14" LCD Cover Replacement: step 4, image 1 of 2 iBook G3 14" LCD Cover Replacement: step 4, image 2 of 2
    • Remove the two Phillips screws securing each side of the LCD to the clutch hinge frame (four screws total).
  5. iBook G3 14" LCD Cover Replacement: step 5, image 1 of 1
    • Lift the thin steel LCD cover off the LCD.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 11
All Time: 53
