iBook G3 14" LCD Cover Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iBook G3 14" LCD Cover Replacement, LCD Cover: step 1, image 1 of 2 iBook G3 14" LCD Cover Replacement, LCD Cover: step 1, image 2 of 2
      • Remove the pieces of readily removable tape from around the perimeter of the display.
      • Carefully remove the aluminum tape covering the display data cable connection.
      Ask FixBot
    2. iBook G3 14" LCD Cover Replacement: step 2, image 1 of 2 iBook G3 14" LCD Cover Replacement: step 2, image 2 of 2
      • Remove the single screw inserted through the piece of EMI tape near the bottom edge of the display.
      • Use the tip of a spudger to remove the small washer under the screw you just removed.
      Ask FixBot
    3. iBook G3 14" LCD Cover Replacement: step 3, image 1 of 1
      • Peel the aluminum/EMI tape off the cast aluminum frame of the clutch hinges.
      • It is not necessary to peel the tape off the thin steel LCD cover.
      Ask FixBot
    4. iBook G3 14" LCD Cover Replacement: step 4, image 1 of 2 iBook G3 14" LCD Cover Replacement: step 4, image 2 of 2
      • Remove the two Phillips screws securing each side of the LCD to the clutch hinge frame (four screws total).
      Ask FixBot
    5. iBook G3 14" LCD Cover Replacement: step 5, image 1 of 1
      • Lift the thin steel LCD cover off the LCD.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 360
