Installing iBook G3 14" Keyboard
  1. Installing iBook G3 14" Keyboard, Battery: step 1, image 1 of 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. Installing iBook G3 14" Keyboard, Keyboard: step 2, image 1 of 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. Installing iBook G3 14" Keyboard: step 3, image 1 of 1
    • If your computer does not have an Airport card installed, skip to the RAM shield removal step.
    • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
  4. Installing iBook G3 14" Keyboard: step 4, image 1 of 1
    • Grasp the clear plastic tab on the Airport card and pull toward the right.
  5. Installing iBook G3 14" Keyboard: step 5, image 1 of 1
    • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
  6. Installing iBook G3 14" Keyboard: step 6, image 1 of 1
    • Remove the two Phillips screws that secure the RAM shield.
  7. Installing iBook G3 14" Keyboard: step 7, image 1 of 1
    • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
  8. Installing iBook G3 14" Keyboard: step 8, image 1 of 1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 7,525
