iBook G3 14" Keyboard Replacement
  1. iBook G3 14" Keyboard Replacement, Battery: step 1, image 1 of 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G3 14" Keyboard Replacement, Keyboard: step 2, image 1 of 1
    • Pull the keyboard release tabs (highlighted in red) toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. iBook G3 14" Keyboard Replacement: step 3, image 1 of 1
    • If your computer does not have an AirPort card installed, skip to the RAM shield removal step.
    • Push the wire clasp toward the AirPort card and pull it up to free it from the RAM shield.
  4. iBook G3 14" Keyboard Replacement: step 4, image 1 of 1
    • Grasp the clear plastic tab on the AirPort card and pull toward the right.
  5. iBook G3 14" Keyboard Replacement: step 5, image 1 of 1
    • Hold the AirPort card in one hand and use your other hand to remove the antenna cable.
  6. iBook G3 14" Keyboard Replacement: step 6, image 1 of 1
    • Remove the two Phillips screws that secure the RAM shield.
  7. iBook G3 14" Keyboard Replacement: step 7, image 1 of 1
    • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
  8. iBook G3 14" Keyboard Replacement: step 8, image 1 of 1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
8 other people completed this guide.
Attached Documents
iRobot
1 Reputation
636 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 26
All Time: 7,764
