eufy Clean RoboVac G32 Pro Power Control Buttons Replacement
    1. eufy Clean RoboVac G32 Pro Power Control Buttons Replacement, Rolling Brush: step 1, image 1 of 1
      • Make sure your device is turned off.
      • Flip the device upside down on a flat surface.
      Ask FixBot
    2. eufy Clean RoboVac G32 Pro Power Control Buttons Replacement: step 2, image 1 of 1
      • Press the clips at the bottom of the device that are indicated by the downward facing arrows.
      • Take off the rolling brush cover.
      Ask FixBot
    3. eufy Clean RoboVac G32 Pro Power Control Buttons Replacement: step 3, image 1 of 1
      • Pull the rolling brush up on the right side. Remove the rolling brush.
      Ask FixBot
    1. eufy Clean RoboVac G32 Pro Power Control Buttons Replacement, Bump Sensor: step 4, image 1 of 3 eufy Clean RoboVac G32 Pro Power Control Buttons Replacement, Bump Sensor: step 4, image 2 of 3 eufy Clean RoboVac G32 Pro Power Control Buttons Replacement, Bump Sensor: step 4, image 3 of 3
      • Orient the device so the underside is facing up.
      • Remove the eight 9.3 mm screws securing the bumper brackets using a Phillips #1 screwdriver.
      • Remove the bumper brackets.
      Ask FixBot
    2. eufy Clean RoboVac G32 Pro Power Control Buttons Replacement: step 5, image 1 of 2 eufy Clean RoboVac G32 Pro Power Control Buttons Replacement: step 5, image 2 of 2
      • Lift the bumper off of the device gently.
      • Use your fingers to disconnect the 8 pin connector.
      Ask FixBot
    3. eufy Clean RoboVac G32 Pro Power Control Buttons Replacement: step 6, image 1 of 2 eufy Clean RoboVac G32 Pro Power Control Buttons Replacement: step 6, image 2 of 2
      • Remove the two 10 mm screws using a Philips #1 screwdriver.
      Ask FixBot
    4. eufy Clean RoboVac G32 Pro Power Control Buttons Replacement: step 7, image 1 of 1
      • Lift the bump sensor off using your fingers.
      Ask FixBot
    1. eufy Clean RoboVac G32 Pro Power Control Buttons Replacement, Power Control Buttons: step 8, image 1 of 2 eufy Clean RoboVac G32 Pro Power Control Buttons Replacement, Power Control Buttons: step 8, image 2 of 2
      • Remove the dust collector by grabbing under the lip and pulling it out.
      Ask FixBot
    2. eufy Clean RoboVac G32 Pro Power Control Buttons Replacement: step 9, image 1 of 1
      • Remove the two 5.5 mm screws using a Philips #1 screwdriver.
      Ask FixBot
    3. eufy Clean RoboVac G32 Pro Power Control Buttons Replacement: step 10, image 1 of 2 eufy Clean RoboVac G32 Pro Power Control Buttons Replacement: step 10, image 2 of 2
      • Remove the eight 14 mm screws using a Philips #1 screwdriver.
      Ask FixBot
    4. eufy Clean RoboVac G32 Pro Power Control Buttons Replacement: step 11, image 1 of 1
      • Lift the bottom housing towards the front.
      Ask FixBot
    5. eufy Clean RoboVac G32 Pro Power Control Buttons Replacement: step 12, image 1 of 2 eufy Clean RoboVac G32 Pro Power Control Buttons Replacement: step 12, image 2 of 2
      • Remove the six 5.5 mm screws securing the button board with a Phillips #1 screwdriver.
      Ask FixBot
    6. eufy Clean RoboVac G32 Pro Power Control Buttons Replacement: step 13, image 1 of 1
      • Grab the 8 pin connector with your hands and firmly pull it away from the board.
      • Remove the board.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Gabe Moore
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 36
All Time: 318
