eMac RAM Door Replacement
  1. eMac RAM Door Replacement, Door Removal: step 1, image 1 of 3 eMac RAM Door Replacement, Door Removal: step 1, image 2 of 3 eMac RAM Door Replacement, Door Removal: step 1, image 3 of 3
    • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
    • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
    • Remove the single phillips #2 screw on the RAM door, and remove the door
    • The screw is captive in the door, so don't worry about losing it.
Chris Green
37,014 Reputation
49 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,539 Guides authored
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 21
All Time: 780
