Shop the Holiday Gift Guide
This guide has more recent changes. Switch to the latest unverified version.
How to Apply Liquid Metal in a PlayStation 5
Views: 165K
View statistics:
Past 24 Hours:
931
Past 7 Days:
8,022
Past 30 Days:
19,702
All Time:
164,679
Comments: 70
67 comments on steps, 3 guide comments.
Go to guide comments
Completed: 45
45 people have marked this guide "completed." Will you be next?
Favorites: 22
22 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to apply liquid metal in your PlayStation 5. You can also use this guide to re-spread existing liquid metal.
Your PS5 has an Accelerated Processing Unit (APU), which uses liquid metal TIM (thermal interface material) instead of traditional thermal paste to transfer heat. Over time, the liquid metal can oxidize or become unevenly spread on the APU and heatsink, especially if the PS5 stood upright for long periods of time. If the liquid metal has oxidized, it'll look dried-out or cracked and will need to be cleaned and replaced. If it's just unevenly covered, you can re-spread it evenly across the surfaces of the APU and heatsink.
Your liquid metal might need to be replaced if your PS5 is overheating, throttling, or having overall poor performance. These signs could also mean a faulty or dirty fan. To remove your fan for cleaning, follow this guide.
Parts
Tools
    1. How to Apply Liquid Metal in a PlayStation 5, Remove the stand screw: step 1, image 1 of 1
      • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
      • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
      • Work on a flat surface to prevent your PlayStation from falling over.
      • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
      Ask FixBot
    2. How to Apply Liquid Metal in a PlayStation 5, Remove the vertical stand: step 2, image 1 of 2 How to Apply Liquid Metal in a PlayStation 5, Remove the vertical stand: step 2, image 2 of 2
      • Lift straight up to remove the stand.
      Ask FixBot
    3. How to Apply Liquid Metal in a PlayStation 5, Store the stand screw: step 3, image 1 of 2 How to Apply Liquid Metal in a PlayStation 5, Store the stand screw: step 3, image 2 of 2
      • Insert the screw into the cubby on the bottom of the stand.
      Ask FixBot
    4. How to Apply Liquid Metal in a PlayStation 5, Cap the screw hole: step 4, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5, Cap the screw hole: step 4, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5, Cap the screw hole: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
      • Use your finger to press the cap into the screw hole.
      Ask FixBot
    5. How to Apply Liquid Metal in a PlayStation 5, Close the cubby: step 5, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5, Close the cubby: step 5, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5, Close the cubby: step 5, image 3 of 3
      • Twist the stand counterclockwise to close the cubby.
      Ask FixBot
    6. How to Apply Liquid Metal in a PlayStation 5, Remove the horizontal stand: step 6, image 1 of 2 How to Apply Liquid Metal in a PlayStation 5, Remove the horizontal stand: step 6, image 2 of 2
      • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
      • Lift the stand straight up to remove it.
      Ask FixBot
    1. How to Apply Liquid Metal in a PlayStation 5, Remove the right faceplate: step 7, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the right faceplate: step 7, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the right faceplate: step 7, image 3 of 3
      • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
      • Lift up the corner of the faceplate to unclip it from the case.
      Ask FixBot
    2. How to Apply Liquid Metal in a PlayStation 5: step 8, image 1 of 2 How to Apply Liquid Metal in a PlayStation 5: step 8, image 2 of 2
      • While lifting up the corner, slide the faceplate towards the bottom of the device.
      • Remove the right faceplate.
      Ask FixBot
    3. How to Apply Liquid Metal in a PlayStation 5, Pry up the grille: step 9, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5, Pry up the grille: step 9, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5, Pry up the grille: step 9, image 3 of 3
      • Insert the flat end of a spudger underneath the grille and into the gap above the fan.
      • Lift up with the spudger to pry the grille away from the case.
      Ask FixBot
    4. How to Apply Liquid Metal in a PlayStation 5, Remove the grille: step 10, image 1 of 2 How to Apply Liquid Metal in a PlayStation 5, Remove the grille: step 10, image 2 of 2
      • Lift the grille away from the case to remove it.
      Ask FixBot
    5. How to Apply Liquid Metal in a PlayStation 5, Remove the fan shroud screws: step 11, image 1 of 1
      Magnetic Project Mat
      $19.95
      Buy
      • Use a TR9 Torx Security driver to remove the four screws securing the fan shroud to the case:
      • Two 23.3 mm-long screws
      • One 11.4 mm-long screw
      • One 31 mm-long screw
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
      Ask FixBot
    6. How to Apply Liquid Metal in a PlayStation 5, Remove the fan shroud: step 12, image 1 of 2 How to Apply Liquid Metal in a PlayStation 5, Remove the fan shroud: step 12, image 2 of 2
      • Lift the fan shroud straight up to remove it.
      Ask FixBot
    7. How to Apply Liquid Metal in a PlayStation 5, Remove the wire cover: step 13, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the wire cover: step 13, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the wire cover: step 13, image 3 of 3
      • Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
      • Pry only on the wire cover, not on the fan wires themselves.
      • Use the spudger to peel up the wire cover until you can grip it with your fingers.
      Ask FixBot
    8. How to Apply Liquid Metal in a PlayStation 5: step 14, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5: step 14, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5: step 14, image 3 of 3
      • Use your fingers to peel off the wire cover.
      Ask FixBot
    9. How to Apply Liquid Metal in a PlayStation 5, Disconnect the fan: step 15, image 1 of 2 How to Apply Liquid Metal in a PlayStation 5, Disconnect the fan: step 15, image 2 of 2
      • Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
      • Always pull cables by their connectors and not the wires themselves.
      Ask FixBot
    10. How to Apply Liquid Metal in a PlayStation 5, Remove the fan: step 16, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the fan: step 16, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the fan: step 16, image 3 of 3
      • Lift the fan up and out of the case to remove it.
      Ask FixBot
    1. How to Apply Liquid Metal in a PlayStation 5, Remove the SSD cover: step 17, image 1 of 1
      • Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
      Ask FixBot
    2. How to Apply Liquid Metal in a PlayStation 5: step 18, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5: step 18, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5: step 18, image 3 of 3
      • Use your finger to slide the SSD cover towards the top of the device to unclip it from the case.
      • Remove the SSD cover.
      Ask FixBot
    3. How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive wire: step 19, image 1 of 2 How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive wire: step 19, image 2 of 2
      • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
      Ask FixBot
    4. How to Apply Liquid Metal in a PlayStation 5: step 20, image 1 of 2 How to Apply Liquid Metal in a PlayStation 5: step 20, image 2 of 2
      • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the optical drive.
      Ask FixBot
    5. How to Apply Liquid Metal in a PlayStation 5, Remove the tamper-evident sticker: step 21, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the tamper-evident sticker: step 21, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the tamper-evident sticker: step 21, image 3 of 3
      Buy
      • Use a pair of tweezers to remove the tamper-evident sticker covering the remaining case screw.
      • If your PlayStation 5 hasn't been opened before, this sticker will be completely black. The pattern will appear after you remove it.
      • Technically, these are tamper-evident stickers—but don't worry—Sony can't legally void your warranty, as long as you don't damage anything. Have fun!
      Ask FixBot
    6. How to Apply Liquid Metal in a PlayStation 5, Remove the case screws: step 22, image 1 of 1
      • Use a TR8 Torx Security driver to remove the eleven screws securing the case:
      • Six 18.6 mm-long screws
      • Two 43.2 mm-long screws
      • One 7.3 mm-long screw
      Ask FixBot
    7. How to Apply Liquid Metal in a PlayStation 5, Remove the case: step 23, image 1 of 2 How to Apply Liquid Metal in a PlayStation 5, Remove the case: step 23, image 2 of 2
      • Lift the case straight up to remove it.
      Ask FixBot
    8. How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive ribbon cable: step 24, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive ribbon cable: step 24, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive ribbon cable: step 24, image 3 of 3
      • Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
      • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
      • Pull only on the pull tab, not the cable itself.
      Ask FixBot
    9. How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive: step 25, image 1 of 2 How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive: step 25, image 2 of 2
      • Lift the optical drive away from the device to remove it.
      Ask FixBot
    1. How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive ribbon cable: step 26, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive ribbon cable: step 26, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the optical drive ribbon cable: step 26, image 3 of 3
      Buy
      • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the motherboard.
      Ask FixBot
    2. How to Apply Liquid Metal in a PlayStation 5, Remove the power and eject button ribbon cable: step 27, image 1 of 2 How to Apply Liquid Metal in a PlayStation 5, Remove the power and eject button ribbon cable: step 27, image 2 of 2
      • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the power and eject button ribbon cable.
      Ask FixBot
    3. How to Apply Liquid Metal in a PlayStation 5, Remove the LED ribbon cable: step 28, image 1 of 2 How to Apply Liquid Metal in a PlayStation 5, Remove the LED ribbon cable: step 28, image 2 of 2
      • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED ribbon cable.
      Ask FixBot
    4. How to Apply Liquid Metal in a PlayStation 5, Remove the antenna wires: step 29, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the antenna wires: step 29, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the antenna wires: step 29, image 3 of 3
      • Use a pair of tweezers to grip the white Wi-Fi antenna wire at its metal base, as close to the connector as possible.
      • Lift the wire's connector straight up to disconnect it from the motherboard.
      • Repeat for the black Wi-Fi antenna wire.
      • Some board revisions may not have these antenna wires. If your board is missing these connectors, skip this step.
      Ask FixBot
    5. How to Apply Liquid Metal in a PlayStation 5: step 30, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5: step 30, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5: step 30, image 3 of 3
      • Use a pair of tweezers to grip the black or blue power supply antenna wire at its metal base, as close to the connector as possible.
      • Repeat for the white power supply antenna wire.
      Ask FixBot
    6. How to Apply Liquid Metal in a PlayStation 5, Remove the white stickers: step 31, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the white stickers: step 31, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the white stickers: step 31, image 3 of 3
      • Use a pair of tweezers to peel back the white sticker holding the antenna wires to the top shield plate.
      • Remove the antenna wires from underneath the sticker.
      • Press the white sticker back down onto the top shield plate so it can be reused.
      Ask FixBot
    7. How to Apply Liquid Metal in a PlayStation 5: step 32, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5: step 32, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5: step 32, image 3 of 3
      • Repeat the previous step to peel back the four remaining stickers.
      Ask FixBot
    8. How to Apply Liquid Metal in a PlayStation 5: step 33, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5: step 33, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5: step 33, image 3 of 3
      • Use a pair of tweezers to peel back the white sticker holding the LED ribbon cable to the heat sink.
      • Remove the LED ribbon cable from underneath the sticker.
      • Press the white sticker back down onto the heat sink so it can be reused.
      Ask FixBot
    9. How to Apply Liquid Metal in a PlayStation 5, Remove the top shield plate screws: step 34, image 1 of 1
      • Use a TR8 Torx Security driver to remove the forty-two screws securing the top shield plate:
      • Forty-one 7.3 mm-long screws
      • One 43.2 mm-long screw
      Ask FixBot
    10. How to Apply Liquid Metal in a PlayStation 5, Remove the top shield plate: step 35, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the top shield plate: step 35, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the top shield plate: step 35, image 3 of 3
      • Lift the top shield plate off of the motherboard to remove it.
      • During reassembly, this is a good point to replace any thermal pads on the top of the main board, if necessary. The pads may be stuck to both the top shield plate and the main board.
      • It's important that the replacement pads are the same thickness as the originals, otherwise the foam around the APU may not seal properly.
      Ask FixBot
    11. How to Apply Liquid Metal in a PlayStation 5, Disconnect the USB board: step 36, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5, Disconnect the USB board: step 36, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5, Disconnect the USB board: step 36, image 3 of 3
      • Use your finger to depress the metal locking tab on the USB board cable's board connector.
      • With the metal tab depressed, place the flat end of a spudger against the insulating foam pad on the ribbon cable and pull it directly away from the connector to disconnect it.
      Ask FixBot
    1. How to Apply Liquid Metal in a PlayStation 5, Remove the main board screws: step 37, image 1 of 2 How to Apply Liquid Metal in a PlayStation 5, Remove the main board screws: step 37, image 2 of 2
      • Use a Phillips screwdriver to remove the 11 mm‑long SSD screw.
      • Be careful not to lose the small spacer under the screw.
      • Use a Phillips screwdriver to remove the two 11.8 mm‑long APU tension bracket screws.
      • Don't remove or install one screw at a time, or you may damage the APU. During disassembly and reassembly, alternate between the two screws a 1/2 turn at a time to maintain even pressure on the bracket.
      • Use a TR8 Torx security screwdriver to remove the two remaining 7.3 mm‑long main board screws.
      Ask FixBot
    2. How to Apply Liquid Metal in a PlayStation 5: step 38, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5: step 38, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5: step 38, image 3 of 3
      • Lift and remove both APU brackets from the board.
      • During reassembly:
      • Put the bracket with plastic arms on first so the pegs go into their cutouts.
      • Then, put the metal bracket onto the plastic one so they're perpendicular and the screw holes line up.
      Ask FixBot
    3. How to Apply Liquid Metal in a PlayStation 5, Separate the main board: step 39, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5, Separate the main board: step 39, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5, Separate the main board: step 39, image 3 of 3
      • Don't try to fully remove the motherboard during this step—the corner near the power button is still secured by metal prongs, which will be disconnected in the next step.
      • Gently lift the edge of the motherboard with the large cutout to partially separate it from the bottom shield plate.
      • With the board lifted, insert the flat end of a spudger between the board and the bottom shield plate and gently twist to separate them. Work your way around the perimeter of the board.
      • Many small thermal pads bond the main board to the metal shield plate underneath. Depending on the age of your PlayStation and the condition of the pads, it may take significant force to separate the board.
      Ask FixBot
    4. How to Apply Liquid Metal in a PlayStation 5: step 40, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5: step 40, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5: step 40, image 3 of 3
      • The power supply is connected to the bottom of the main board assembly by metal prongs that plug into the bottom left corner.
      • Insert the flat end of a spudger between the board and the lower shield plate, by the two parallel solder joints near the corner with the power button.
      • Twist the spudger to lift the two prongs under the board out of their socket.
      • You should feel the prongs slide out.
      • During reassembly, press down on the corner of the board to fully seat the prongs in the power supply—you should feel them slide into place.
      Ask FixBot
    5. How to Apply Liquid Metal in a PlayStation 5, Remove the main board: step 41, image 1 of 2 How to Apply Liquid Metal in a PlayStation 5, Remove the main board: step 41, image 2 of 2
      • Remove the main board, flip it over, and carefully lay it on a clean work surface, so the APU is facing up.
      • Don't press the board against your work surface, or you may damage fragile components.
      • Make sure all cables that connect to the board are out of the way so they don't get trapped underneath.
      • Carefully flip the board over so the APU is on the bottom, making sure no liquid metal spills.
      • Keep the board level and lower it into place.
      Ask FixBot
    1. How to Apply Liquid Metal in a PlayStation 5, Remove the old liquid metal from the heatsink: step 42, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the old liquid metal from the heatsink: step 42, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5, Remove the old liquid metal from the heatsink: step 42, image 3 of 3
      Dispensing Syringe Kit 9 pieces
      $8.99
      Buy
      • Wear gloves to protect your skin from the liquid metal.
      • If you have a disposable syringe, you can use it to suck up any large pools of liquid metal. Don't use the syringe containing your new liquid metal.
      • Starting with the heatsink: apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to a cotton swab and carefully clean up all of the liquid metal from the heatsink surface.
      • Removing the liquid metal can be tricky—it spreads and smears easily. Switch to new cotton swabs and apply more alcohol as necessary.
      • Use the same cleaning process to thoroughly clean up all of the liquid metal residue.
      • The surface needs to be completely clean for the new liquid metal to work properly.
      • Let the heatsink dry completely.
      Ask FixBot
    2. How to Apply Liquid Metal in a PlayStation 5, Remove the old liquid metal from the APU: step 43, image 1 of 2 How to Apply Liquid Metal in a PlayStation 5, Remove the old liquid metal from the APU: step 43, image 2 of 2
      • Don't remove the foam barrier that surrounds the APU.
      • Just as you did for the heatsink, clean and remove all of the old liquid metal and its residue from the APU.
      • Don't let any of the liquid metal drip onto the board. Liquid metal is conductive and could cause a short. The foam barrier keeps the liquid metal from leaking out.
      • This is a good point to replace any thermal pads on the bottom of the main board, if necessary. The pads might be stuck to both the bottom shield plate and the main board.
      • Make sure your replacement pads are the same thickness as the originals, or the foam around the APU may not seal properly.
      Ask FixBot
    3. How to Apply Liquid Metal in a PlayStation 5, Apply new liquid metal: step 44, image 1 of 3 How to Apply Liquid Metal in a PlayStation 5, Apply new liquid metal: step 44, image 2 of 3 How to Apply Liquid Metal in a PlayStation 5, Apply new liquid metal: step 44, image 3 of 3
      • Apply a small drop of liquid metal to the heatsink (not the APU)—about the size of a small matchstick head.
      • If your liquid metal syringe has multiple applicator heads, use the one with a small, needle-like tip.
      • Use the spreader that came with your liquid metal or a new cotton swab to lightly push down on and evenly spread the liquid metal across the entire surface.
      • If there's excess liquid metal anywhere, use the syringe to suck it back up.
      Ask FixBot
    4. How to Apply Liquid Metal in a PlayStation 5: step 45, image 1 of 2 How to Apply Liquid Metal in a PlayStation 5: step 45, image 2 of 2
      • Your cotton swab from the previous step should still have some liquid metal left on it.
      • Use the same cotton swab to spread a thin layer of liquid metal evenly onto the APU. If you need more liquid metal, lightly dab the cotton swab on the heatsink to transfer some, or apply a very small drop from the syringe.
      • The main board is now ready for reassembly.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order, starting with this step.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
45 other people completed this guide.
Author
with
Spencer Day
210,455 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
3 Guide Comments
Una domanda se posso:
Come mai su tutti i video tutorial spargono il metallo liquido sia sul dissipatore che sull'apu?
Quanti gr di liquido metallico necessitano in totale?
Tonynox - Reply Share
J'ai effectué le grand nettoyage de ma console PlayStation 5 1ère génération version Disque.
J'ai effectué également le changement du liquide métal, que j'ai acheté sur Amazon (1gr).
C'était plus facile de démonter que de remonter...
Par contre sur l'étape 37 je n'ai pas les mêmes vis, il faut sur ma console les enlevées par l'arrière de la protection noir (socle), 2 vis.
Sinon tout est ok, j'ai mis environ 2 heures, c'est la 1ère fois que je fais ça.
Pour étaler le liquide métal, ce n'est pas facile, j'ai un peu galérer...
Et je n'ai pas réussi a nettoyer correctement la base, il y avait des morceaux qui ne s'enlevaient pas.
En tout cas merci du partage, le tutorial est super, c'est un excellent travail.
J'ai quand même une grande colère envers Sony pour avoir vendu une console aussi chère pour une qualité aussi pourrie...
Enfin bon ! Merci !
(J'ai oublié de dire que ma console était toujours à la verticale, le liquide a coulé, cela se voyait... Maintenant elle est a l'horizontale :)
Merci
Ludwin L - Reply Share
This is my go-to guide to have open on a secondary monitor while cleaning out PS5 units to ensure I don't miss anything. Well documented and excellent photos showing the locations and types of screws involved. Thanks for taking the time to post this!
Josh Cooper - Reply Share
Past 24 Hours: 931
Past 7 Days: 8,022
Past 30 Days: 19,702
All Time: 164,679
