Shop the Holiday Gift Guide
How to Use a Desoldering Pump
Views: 127K
View statistics:
Past 24 Hours:
61
Past 7 Days:
484
Past 30 Days:
1,978
All Time:
126,843
Comments: 8
3 comments on steps, 5 guide comments.
Go to guide comments
Completed: 96
96 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 seconds - 2 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
A desoldering pump (or solder sucker) is a handy tool that sucks molten solder. You can use it to desolder through-hole components on a circuit board or to rework bad solder joints.
This guide shows how to use and clean iFixit’s desoldering pump. You may need to use some soldering wick to clean up any solder remnants—follow this guide on how to use soldering wick.
Tools
    1. How to Use a Desoldering Pump, Prime the pump: step 1, image 1 of 2 How to Use a Desoldering Pump, Prime the pump: step 1, image 2 of 2
      Tool used on this step:
      Desoldering Pump
      $3.99
      Buy
      • If this is your first time using a desoldering pump, try priming and activating the pump a few times before you use it for desoldering purposes.
      • Firmly grasp the desoldering pump with your hand.
      • Depress the plunger until it locks in place.
      • This primes the spring-loaded piston for suction.
      Ask FixBot
    2. How to Use a Desoldering Pump, Activate the pump: step 2, image 1 of 2 How to Use a Desoldering Pump, Activate the pump: step 2, image 2 of 2
      • To activate the pump, press the black side button.
      • This releases the spring-loaded piston, which creates a burst of suction at the nozzle.
      • The piston release creates a substantial kickback. Brace your hand when you use the pump to keep the nozzle steady.
      Ask FixBot
    3. How to Use a Desoldering Pump, Desolder a joint: step 3, image 1 of 3 How to Use a Desoldering Pump, Desolder a joint: step 3, image 2 of 3 How to Use a Desoldering Pump, Desolder a joint: step 3, image 3 of 3
      FixHub Smart Soldering Iron
      $79.95
      Buy
      • Do not use the desoldering pump to desolder joints near small surface-mounted (SMT) components. The heat spillover and suction may dislodge the SMT components.
      • Prime the desoldering pump by depressing the plunger.
      • Heat the solder joint until the solder is liquified. To help with heat transfer, add some solder onto the soldering iron's tip.
      • Position the pump's nozzle as close to the molten solder as possible.
      • The nozzle is made of heat-resistant plastic, so don't worry if you occasionally brush the tip with it.
      • Press the side button to activate the pump.
      • Repeat the process until the joint is clean. You can also use solder wick to help soak up any remnant solder.
      Ask FixBot
    4. How to Use a Desoldering Pump, Clean the desoldering pump: step 4, image 1 of 3 How to Use a Desoldering Pump, Clean the desoldering pump: step 4, image 2 of 3 How to Use a Desoldering Pump, Clean the desoldering pump: step 4, image 3 of 3
      • To clean the pump, prime and activate the pump a few times. This pushes a rod through the nozzle and ensures that solder doesn't block it.
      • On the rare occasion when the pump needs a more thorough cleaning, you can disassemble the pump to clean it out:
      • Grasp the nozzle by its knurled edge.
      • Twist the nozzle counter-clockwise to unscrew it. This may be difficult due to a tight-fitting O-ring.
      • Remove the nozzle and clean out the pump interior.
      Ask FixBot
For soldering instructions and tips, follow this guide.
96 other people completed this guide.
Author
with
Arthur Shi
354,059 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
5 Guide Comments
Good review, but I’ve found that these small solder suckers don’t do a very good job. The much larger “Soldapult” (https://www.edsyn.com/product/DS017.html) provides much more suction and can often completely clear a joint in one use.
shamino - Reply Share
How does the tip not melt.
Mia Cipollone - Reply Share
Apply higher temperature on your soldering iron, above 380°C.
Use bigger tip, bigger heating surface provides more effecitive heat transfer.
SchwarzeKatz - Reply Share
If you are asking about why the tip of the solder sucker doesn't melt, it is made of a heat resitant material. Notice the word resistant.
Budda Belly - Reply Share
Realmente me estoy interesando en este rubro y espero çontinuar aprendiendo para que me sirva como terapia
Jaime Rivera - Reply Share
Past 24 Hours: 61
Past 7 Days: 484
Past 30 Days: 1,978
All Time: 126,843
