Introduction
Welcome to the Zoom H1 Handy Recorder guide to replace the USB port. It will happen at times that the USB port corrodes, suffers damage, or ages in quality, making the recorder not read devices properly or not connect at all. This guide will provide step-by-step instructions to help you replace the USB port. Tools needed to complete tasks are listed below. Although this guide is easy to follow, there is a special skill necessary: soldering.
Caution! About soldering: there are some hazards to be aware of, necessary equipment, and the act of soldering itself. Luckily, iFixit has a Wiki on all of the above! Click here to access the Wiki. Now go and make your Zoom H1 Handy Recorder work like new again!
Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
Unscrew the circuit board screw.
This screw is located down near the bottom of the device on the blue circuit board. It is just to the right of the USB port.
Use a plastic removal tool to disconnect the blue circuit board from the green circuit board underneath.
Place the new USB port in the same spot on the board, and re-solder at each of the four points.
Ensure you re-solder the wire into the same connection you removed it from during desoldering
Rotate the circuit board back to its initial position, with the port on the underside of the board.
