Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
Unscrew the circuit board screw.
This screw is located down near the bottom of the device on the blue circuit board. It is just to the right of the USB port.
Use a plastic removal tool to disconnect the blue circuit board from the green circuit board underneath.
Place the new USB port in the same spot on the board, and re-solder at each of the four points.
Ensure you re-solder the wire into the same connection you removed it from during desoldering
Rotate the circuit board back to its initial position, with the port on the underside of the board.
