Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
De-solder the white and black speaker wires from their soldering points.
Speaker soldering points are located on the thin section of the blue circuit board, and are marked with “SP+” and “SP-”.
Remove the damaged speaker from its place at the very bottom of the case, just below the battery input.
Replace the damaged speaker and re-solder to the original solder points.
Ensure that the negative wire is soldered to the “SP-” while the positive wire is soldered to the “SP+” point.
