Introduction
You might want to remove the back panel of your Xiaomi Redmi Note 13 Plus Pro 5G (Models 23090RA98C, 23090RA98G, 23090RA98I) if it is damaged or if you need to access the internal components.
This guide can be used as a prerequisite to access the following components: battery, ringer, motherboard, screen, etc.
In this guide, we will guide you through the removal of the back panel of the Redmi Note 13 Pro Plus 5G. You will need to use an iOpener to remove the phone's back panel by melting the adhesive that keeps it shut.
Disconnect the device from all external power sources before disassembling.
Place the suction handle on the back panel of the phone.
While lifting the suction handle, insert the opening tool in the space created by the pulling. Try to widen the space between the back panel and the rest of the phone.
When that space is wide enough, insert at least two opening picks.
