Xbox Series S Foot Replacement
  1. Xbox Series S Foot Replacement, Set your Xbox down: step 1, image 1 of 2 Xbox Series S Foot Replacement, Set your Xbox down: step 1, image 2 of 2
    • Place your Xbox on your work surface so that the foot you're replacing is facing upward.
  2. Xbox Series S Foot Replacement, Pry up the old foot: step 2, image 1 of 3 Xbox Series S Foot Replacement, Pry up the old foot: step 2, image 2 of 3 Xbox Series S Foot Replacement, Pry up the old foot: step 2, image 3 of 3
    • This step shows how to remove a loose foot. If your Xbox is already missing the foot, skip this step!
    • Insert the point of a spudger underneath one end of the foot.
    • Pry up to separate the foot from the Xbox.
    • Remove the foot.
  3. Xbox Series S Foot Replacement, Clean the footwell: step 3, image 1 of 3 Xbox Series S Foot Replacement, Clean the footwell: step 3, image 2 of 3 Xbox Series S Foot Replacement, Clean the footwell: step 3, image 3 of 3
    • Cleaning the footwell will drastically help the new foot to stay on your Xbox.
    • Apply a drop of >70% isopropyl alcohol to the footwell.
    • Use the point of a spudger or a toothpick to scrape and loosen any adhesive residue in the footwell.
    • Wipe the footwell with a lint-free cloth or a coffee filter.
  4. Xbox Series S Foot Replacement, Replace the foot: step 4, image 1 of 3 Xbox Series S Foot Replacement, Replace the foot: step 4, image 2 of 3 Xbox Series S Foot Replacement, Replace the foot: step 4, image 3 of 3
    • Pick up a foot from the replacement sheet.
    • Align the foot in its footwell.
    • Use your finger to press the foot down for ten seconds to secure it onto your Xbox.
If your Xbox is missing additional feet, repeat the procedure to replace them.
Arthur Shi
309,324 Reputation
699 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,583 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 63
All Time: 869
