Introduction
Use this guide to install a new outer case for the Nintendo Wii U GamePad and gain access to the touchscreen and buttons.
Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover.
Lift up and remove the battery cover.
With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
Pull upwards from the bottom of the battery to release it.
Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
Lift up the back plate.
